XDcam transfer from FCP for AVID? - Page 2 at DVinfo.net
Convergent Design Odyssey
Old February 5th, 2009, 02:11 PM   #16
Dear Mark,
Thanks for the offer!
That would be great.
...Can someone post a QT out of FCP encoded with the sheer video codec, please ?
Mark Job is offline   Reply With Quote
Old February 6th, 2009, 02:59 PM   #17
Sorry I haven't seen this sooner!
Just install the Avid Codec package on the Mac you use for Final Cut. Once you've done that (and restarted final cut) you'll have all the Avid codecs available.
Choose export using quicktime conversion then in options under compression type choose Avid DNxHD.
Other options available are Depth (Millions of Colors) and Resolution (1080i/59.94 DNxHD 220 8 or 10 bit)
Size (set to 1920x1080)
Color (Use either just tell the editor which one you used so his black levels are correct)
Set your audio options (linear PCM / Stereo / 24 bit sample size)
OK!
The file imports into the Avid, no problem.
Michael Palermo is offline   Reply With Quote
Old February 6th, 2009, 03:04 PM   #18
Here's the link to Avid Codecs:
Answer
Also I noticed your editor will be able to fast import if you set your color to 709 on export.
Old February 6th, 2009, 03:08 PM   #19
Make sure the Editor is working on an HD capable Avid by the way, many of them aren't.
Old February 6th, 2009, 05:33 PM   #20
Hey Mike:
This is good news. I appreciate the AVID coded info.
Cheers,
Scott
Douglas Scott is offline   Reply With Quote
Old February 6th, 2009, 05:57 PM   #21
Thanks again Mike Palermo.
I just downloaded the codec and exported a movie from FCP with the AVID codec. It seems to work just fine. That's just what I needed!!!
Cheers,
Scott
