NanoFlash Mount for AB Batteries and Canon XL H1S at DVinfo.net
Convergent Design Odyssey
Old June 15th, 2009, 04:01 PM   #1
Hey guys,
I've seen the custom mount you made for the Flash XDR with use with AB Dionic 90's and the Canon XL.
Do you have something of similar nature for the NanoFlash as well? I am trying to figure out a solution. I have the XL H1S which I power with a Dionic 90 mounted to the back bracket. I'm trying to figure out where to put the NanoFlash as I need the hotshoe free and I need to power the Nano from the D-Tap from the Anton Bauer.
Thanks.
Michael Galvan is offline   Reply With Quote
Old June 16th, 2009, 07:15 PM   #2
Convergent Design
Hi Michael-
We are still working on possible mounts. We do have a comprehensive mechanical drawing of the nanoFlash on the website. The nanoFlash has threaded mounting holes on the side, bottom and top of the box (two mounting holes on each surface).
In the interim, you might consider velcro. The new industrial strength velcro is incredibly strong and works well with the 1 lb nanoFlash.
Best-
Mike Schell
Convergent Design
Mike Schell is offline   Reply
