DV Magazine Review of the nanoFlash - Page 3 at DVinfo.net
Convergent Design Odyssey
Old May 14th, 2010, 10:13 AM   #31
Dropping bits versus dithering them
Originally Posted by John Mitchell View Post
I think the answer is Mark that CD throw away the extra 2 bits. Currently the Nano wold just throw away those last two numbers and end up with a slightly different result...1.0000000.
I'm not sure what the impact on the final image would be - maybe slightly smoother gradients?
...Hi John: The question is which procedure works better ? Can one see the difference ? Is it better to just do away with the extra 2 bits of precision, or dither the 10 into 8 ? Which looks better ? I would think it is probably more efficient to just drop the extra 2 bits, so that the internal Nano/XDR processor doesn't have to work as hard. I'm guessing that dithering 10 bits into 8 uses allot of processor power. (??) Is this accurate Tommy ?
Mark Job is offline   Reply With Quote
Old May 14th, 2010, 02:08 PM   #32
My guess is as well that dithering 10bit to 8bit will be a waste. MPEG-2 is an 8-bit codec. As I said in the article, 8-bit color is more than adequate for a number of shooting scenarios. If you need 10bit (or greater) color sampling, then you simply need a different codec (read here, different device). Each tool has its place. nanoFlash works perfectly for me.
Ned Soltz
Ned Soltz is offline   Reply With Quote
Old May 14th, 2010, 02:26 PM   #33
Ned Soltz
Exactly. No software application or piece of hardware is optimized for every possible scenario.
TimK
Kolb Productions
Tim Kolb is offline   Reply With Quote
Old May 14th, 2010, 04:00 PM   #34
The XDR Works well for me
Ned Soltz
....The XDR works perfectly for me as well.....But it could work even more perfectly if I had the *U* option for digital cinema origination. (Doing my best not to thread camp on that one Chris)
Old May 22nd, 2010, 02:03 AM   #35
Ned Soltz
Perhaps, but dithering is a pretty accepted way to enhance an information resolutiong change, and it's considered superior to truncating, simple rounding or adding zeros.
I do think it has more value when up-rezing than when down-rezing, so you may be right.
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0
Old July 3rd, 2010, 06:53 PM   #36
Cash Cab XDR
Originally Posted by Mark Job View Post
Hi Rafael:
....Cash Cab is all 8 bit XDR's.
Nice video of their set-up.
YouTube - On Set with the HD Flash XDR - Camera Department
Jose Carlos is offline   Reply
