when to use remove pull down? at DVinfo.net
Convergent Design Odyssey
Old April 6th, 2010, 07:39 AM   #1
If Iam shooting HDX900 1080i/59.94 system setting.. 24p camera setting.. giving me 23.98p rec run TC embedded to Nano.Recording 50Mbps/QT.To be edited FCP
Do I need to tick remove pull down?
Robin Probyn is offline   Reply With Quote
Old April 6th, 2010, 09:21 AM   #2
Dear Robin,
I would check the Remove pulldown checkbox.
Note: This is easier than it seems.
You want to record 23.98 (sometimes called 24p, and sometimes called 23.976 which is more precise, but the same thing).
If the nanoFlash is setup up properly, it will say 23.98 (or similar) near the bottom of the screen. If it says something else, either the camera or nanoFlash is not setup correctly.
I recommend to you, and to everyone else, that they run a test, with their camera, and their nanoFlash, and take the footage into Post, to see that you have everything correct.
Dan Keaton
Augusta Georgia
Old April 6th, 2010, 09:56 AM   #3
Robyn, use 3:2 pulldown in the following situation:
You set your camera to 24p (or 23.98, 23.976) but the signal coming out of the SDI port is 59.94.
3:2 pulldown will restore the 59.94 to a proper 24p and record it to the CF cards.
I can not think of another situation where you would need 3:2 pulldown.
Aaron Newsome is offline   Reply With Quote
Old April 6th, 2010, 10:57 AM   #4
Robin:
Set your HDX-900 and NanoFlash up and try this.
When the HDX-900 is set up for 1080:
59.94 / 24p
With the:
Record PSF Prog Unchecked.
Look at the bottom line of the NanoFlash screen and you will see:
1080i59 (with the Record PSF Prog Checked you will see 1080sf29)
Now:
Check the Remove 3:2 Pulldown and watch this line change to:
1080pd23
Now:
Set the HDX-900 for:
59.94 / 30p
With the:
Remove 3:2 Pulldown Unchecked.
You will see 1080i59 at the bottom line of the screen.
Now:
Uncheck the Record PSF Prog.
Now:
Check the Record PSF Prog.
You will see 1080sf29 on the bottom line.
Now check the Remove 3:2 Pulldown and what you have on the bottom line. If you see bottom line reading "No SRV" then you know you need to make a change.
Once you go through this a few times it will all make sense. Decide what format you want to shoot then set your HDX-900 up and then your NanoFlash. Make sure you have your chosen format in your camera and on the bottom line on the Nano Screen.
Beware.... If you try this with color bars as a video source you will not see a 1080pd23 signal Reading on the NanoFlash. So don't test this with Color Bars.
Now I think I'm confused. Let me know if this helps.
Dusty Powers is offline   Reply With Quote
Old April 6th, 2010, 06:09 PM   #5
Hi Dusty/Dan/Aaron
Thanks for the info! I think I get it..great..
Old April 6th, 2010, 11:41 PM   #6
Originally Posted by Dusty Powers View Post
Robin:
59.94 / 24p
With the:
Now:
1080pd23
Now:
59.94 / 30p
With the:
Now:
Now:
Loaded in the new software.. did all the settings..shot a test and play back.. all well 23.98 it is!!!
Thanks for the details.. that 29 to 24 when remove pull down is applied is a tricky one.. that would have confused me for sure..
Thanks again for your support.. everyone...
Know to work out Crank???? dont get it so far..
