Flash XDR Release Notes - Release Version 1.5.86 at DVinfo.net
Convergent Design Odyssey
Old October 11th, 2010, 11:59 AM   #1
Dear Friends,
As we are finishing the testing of the Flash XDR release, I thought it would be helpful for us to post this list of release notes for the upcoming release.
(These notes are subject to change as we may add some more features.
The Release Version and Release Date are not yet finalized.)
Flash XDR Release Notes Release Version 1.5.86 (Oct - 2010 )
o Fixed green frame bug at beginning of long-Gop MXF files when brought into Sony Vegas.
o Added timecode trigger delay (System->Timecode->Trigger Delay), in number of seconds.
When used in combination with “Timecode” trigger or “TC > Last TC” trigger (System->Trigger),
Flash XDR will delay start of record the specified number of seconds in the Trigger Delay.
This feature is beneficial to better match the timecode of some tape-based cameras,
which can shift the camera timecode unexpectedly at the beginning of camera record.
This feature also helps to prevent the Flash XDR from creating very small files in Timecode trigger mode if the camera is shifting it's timecode around while ejecting / inserting media.
o SD Aspect Ratio (Video->SD Aspect Ratio) fixed. In earlier versions, this was not always being applied correctly to files.
o Added lock-out of drop-frame timecode in 720p24 mode. ( In some NLE's, drop-frame timecode is not allowed in 720p24 mode. )
o Fixed timecode bug in 720p24 mode with pulldown removal. Timecode was getting inadvertently doubled in this mode, but is now correct.
o LTC timecode accuracy improved.
o Improved MPG support.
o Added ability to create new file during record by pressing Record button while in Timecode Trigger mode. (This method was previously available only with Record button as the Record trigger (System->Trigger) ).
o Fixed compatibility with newer Delkin CF cards 420x and 450x.
o Avid has added AMA compatibility, “Link to AMA Files”, for Flash XDR MXF files.
Allows access of files within Avid without having to import (copy in) the files.
Requires Avid Patch 5.0.3.2 .
o Added Vertical image flip (Video->Flip V) and Horizontal image flip (Video->Flip H) options for flipping images as desired from camera outputs in which the camera lens produces an inverted image.
o Fixed bug in Crank mode, in which during long records, all files after the 1st file would not use the cranked rate properly.
o Fixed Remote trigger bug introduced in 1.5.249 beta, in which file corruption could occur when using Remote trigger option.
o Corrected errant “Intermittent Source” which appeared on Flash XDR especially in 720p mode from cameras such as the Panasonic HDX900 during record, and would cause some seconds' loss of footage.
o Repaired playback from Flash XDR of Standard Def, timecode and audio are now properly played back.
o Changed menu option to select File Format (in the System menu) : the option is now under “File= “ (also in the System menu. Scroll to the far right (using right arrow) of the “ File= “ menu option to set the file format: .MOV, .MXF, or .MPG . The explicit “File Format” option has been removed.
o Improved reliability in .MPG file format.
o Eliminated rare horizontally shifted video in 1080p25 recordings.
o Fixed audio / video sync during playback from Flash XDR.
o Changed Standard Def IMX (MXF files), number of audio channels from 8 channel 16 bit to 4 channel 24 bit (with only the 1st 2 channels actually used). The IMX specification requires one of the 2 above mentioned options, the 2nd option is now used to support 24 bit audio.
o Fixed bug in 8 channel audio, HD MXF recordings, which improves compatibility with Edius.
o Added Screen Tally option (Video->Screen Tally), which places a red bar on the output to indicate unit is recording.
Video->E to E must be turned on for Screen Tally to work correctly.
o Turned off “Read Only” status for all recorded files.
o Creation Time / Date is now correctly stored in .MXF files.
o Corrected bug which blocked recording after “No Last Clip” message.
o Changed “Unit ID” in System menu to “File=”, which allows user to set the 1st 2 digits / characters of the file name as before (formerly the Unit ID), and additionally the next 3 digits (the clip number). Take care to avoid duplicate file names on the same CF card.
Known issues (1.5.86):
o 720p24 / 25 / 30 playback from the Flash XDR is not supported at this time.
o Pulldown removal from JVC 700 requires turning the Flash XDR on 1st, then the camera, to work properly.
o Avid Media Composer: does not support Long-Gop MXF files 100 Mbit and above.
(All I-Frame files, all bit rates are supported.)
Avid Media Composer Does not support any 720p24/25/30 files at 50 Mbit and above.
Dan Keaton
Augusta Georgia
Old October 11th, 2010, 05:28 PM   #2
Upcoming Release 1.5.86 for Flash XDR
Hi Dan:
Good to see many fixes included in this latest update. I have a few questions about other fixes not listed. Such as........
1. Jam-Sync drift error when using 1080 24 F 3:2 pull down removal.
2. Menu character screen size: Enlarging characters including little hour glass at least three sizes larger.
3. Playback glitching in 1080 playback. (Intermittent audio disappearing or screeching and popping) Sometimes you have to press play and stop and play again up to 3 times before normal playback condition resumes.
4. Intermittent Playback Time Code display.
What is the status of these repairs ? Playback from the XDR is a must to show director last take.
Mark Job is offline   Reply With Quote
Old October 11th, 2010, 06:21 PM   #3
Dear Mark,
When producing a new release, one of the hardest things to do is to keep track of all of the fixes, changes, and improvements.
I will check on the items in your list.
Item 1, I do not know the status of this condition.
Item 2, your request, has not been done. You requested this after we had already started testing this release.
I do not see how we can increase the size of the characters and still keep the same number of lines. Maybe you see something that I do not see.
We have not yet discussed your recent request to make the hourglass bigger. I like the idea.
Item 3, I do not think you will find this in this release.
Item 4, Intermittent Timecode display may be linked to us putting out an error message in the same space on the LCD. On the nanoFlash I know that we put out "No Timecode" which does not really have any meaning during playback, as no camera is required to be present.
Dan Keaton
Augusta Georgia
Old October 11th, 2010, 06:46 PM   #4
Menu Size & Line Resolution
Hi Dan:
OK. Understood. I was wondering if the larger hour glass thingy and the now present Monitor Record Bar feature would be enough ? I can't really think of any other feature to stuff in the XDR other than the ones I already have constantly harped on ! ;-) Can you ? Maybe hot swopping the cards, but with 4 slots and 64 GB approved CF cards (128 GB on the way soon), I don't see a big need for that, but it would be nice if you have a whole bunch of low capacity cards and want to use them on long interviews and public speakers. Hey can you turn on the Fire Wire socket ? If you could download or Avid AMA your XDR files without having to unplug them from the XDR, then you save big time having all those extra insertions and ejections of the CF media. (less wear and tear on the unit itself and increasing clip downloading in the field versus using the USB 2.0 reader)
Old October 12th, 2010, 06:54 AM   #5
Dear Mark,
We had not put out a Flash XDR release for quite some time due to other projects that we were working on.
So, we concentrated on the Flash XDR to get a release ready.
Thus, we started our testing, then tried to get everything perfect. If we found a problem, we fixed it.
During this repetitive process, we were also working on other things. But, we froze the Flash XDR so as to not introduce new problems which would delay the release.
We never planned on using the 4-Pin Firewire socket on the Flash XDR to perform file transfers to a computer.
Dan Keaton
Augusta Georgia
Old October 12th, 2010, 07:08 AM   #6
If it's there then why not ?
Hi Dan:
I figured that since it's there, then why not use it ? Is it complicated to turn that socket on ? Does it require some sort of special programming ?
Old October 12th, 2010, 08:14 AM   #7
Dear Mark,
Yes, it is a major project to emulate / support all of the commands sent by a computer in the mode that you are requesting.
You are requesting that the Flash XDR emulate four disk drives and handle all of the commands that a Firewire connected disk drive supports.
Dan Keaton
Augusta Georgia
Old October 12th, 2010, 08:24 AM   #8
HDD Emulation
Hi Dan:
OK. I was just thinking of data download from the CF cards. But I don't know what kind of emulation routines have to run for that. (??) If you folks at CD want to make that a paid upgrade for those Nano/XDR users who might want that, then I don't mind. I would pay to have that.
Old October 12th, 2010, 04:22 PM   #9
To add to what Dan says:
1) using jam-sync with pulldown removal is a bit of a messy combination, involving 2 different timebases (29.97 for the original signal, 23.98 for the jam sync), this may not be any better in the new firmware.
4) I believe the intermittent blinking "no timecode" message during playback is fixed.
Tommy
Tommy Schell is offline   Reply With Quote
Old October 12th, 2010, 05:54 PM   #10
Hey Tommy :-)
.....I was wondering about this myself. First, you are asking the on board computer to calculate 3:2 pull down removal in realtime 24 over 59.94i, then you are asking that *corrected* 24p stream to remain in synchronization with a constant TIME CODE reference. I am guessing here that the 3:2 pull down removal process is slowing down the jam-sync ? Is there any way to circumvent this effect ? (If indeed my premise is correct) (??)
Tommy
....Oh thank you Tommy :-) ! This blinking TC display was practically giving me seizures !
Old October 14th, 2010, 07:47 AM   #11
Are we in for this XDR firmware release this week?
John Richard is offline   Reply With Quote
Old October 14th, 2010, 09:42 AM   #12
Dear John,
I am sorry, but no.
In our quality control testing, we found some problems.
We made a new build yesterday and it is in test again today.
Dan Keaton
Augusta Georgia
Old October 14th, 2010, 07:07 PM   #13
Thanks Dan.
Better to have it rock solid stable. Thanks for the deep testing.
Old October 14th, 2010, 07:23 PM   #14
Dear John,
We greatly appreciate your patience and understanding.
Dan Keaton
Augusta Georgia
Old October 14th, 2010, 08:47 PM   #15
I Second This...
Originally Posted by John Richard View Post
Thanks Dan.
....Hi John & Dan:
Yes. I too second this. It is better to wait longer and have *STABILITY* and *RELIABILITY* in a release. I care more about these two aspects than any other feature :-) I am using my XDR on a major paying TV documentary production right now.
