Different weight measurments for Lithium Ion battery to power the Nanoflash at DVinfo.net
Convergent Design Odyssey
Old October 12th, 2010, 07:45 AM   #1
I asked Dan personally but I think it's a good question to have on the forum.
What's the weight difference between the 4-cell and 8-cell batteries nanoflash now offers to power the nanoflash?
In other news I just preordered the Panasonic AF100 - very excited to use this camera with the nanoflash.
Ed David is offline   Reply With Quote
Old October 12th, 2010, 09:36 AM   #2
Very interesting solution Ed for those who haven't invested in Anton Bauer/V-lock battery systems. I just had a look at this new offering on nanoflash.net. With a bit of industrial strength velcro you're off to the races. The cost savings are significant. The one weak point would be where the cable attaches to the battery cells.
Ed have you been able to determine how much the AF100 weighs and does it come with a kit lens?
Old October 12th, 2010, 11:24 AM   #3
Dear Ed,
The 8-Cell Lithium-Ion battery offered by nanoFlash.net is 13.7 ounces.
The weight of the 4-Cell is about 7.5 ounces.
The weight of the 2-Cell is about 4 ounces.
While the 2-cell, 2,600 mah Lithium-Ion battery supplies about 3 hours of recording time, the 4-Cell, 5,200 mah battery will provide more than twice the amount of recording time.
The 8-Cell battery is 8,800 mah, or 3.38 times the 2,600 mah of the 2-Cell battery, but should provide more than 3.38 times the recording times.
Rick Kelly of nanoFlash.net will be posting on his website the size and weights of each battery as soon as possible.
The 4-Cell and 8-Call batteries may be charged, quickly, by the 2.7 amp charger. This charger is not appropriate for the 2-Cell battery.
The 8-Cell battery is appropriate for powering the nano3D or powering one nanoFlash for an extended period of time.
Dan Keaton
Augusta Georgia
Old October 12th, 2010, 01:54 PM   #4
2-cell battery and nano3D
Dear Dan,
This question maybe was explored before and my apologies if it has been. Also, I am sorry for may not posting in a proper Thread.
I have 3 sets of 2-cell of the while 2-cell, 2,600 mah Lithium-Ion batteries. Are they good to power nano 3D set?, duo 2D set? and if yes is the powered time differ from the regular single 2D NF?
Thank you
Luben
Luben Izov is offline   Reply With Quote
Old October 12th, 2010, 02:41 PM   #5
Dear Luben,
The nano3D consists of two nanoFlashes, as you are well aware.
The nano3D is normally powered via one power source, through a single 4-Pin Hirose Connector.
However, the "Y" power cable that comes with the nano3D may be removed, then you can power each nanoFlash separately.
If you power the two nanoFlashes separately, then you may use two of the 2-Cell Lithium-Ion batteries and they will work fine for around 3 hours.
If you want to use one battery to power both, we recommend the 8-Cell battery and the 2.7 amp medical grade charger.
Dan Keaton
Augusta Georgia
Old October 12th, 2010, 08:08 PM   #6
Thank you Dan for the reply!
Today I received my nano3D!!
Cheers
