crackling audio at DVinfo.net
Convergent Design Odyssey
Old October 28th, 2010, 01:27 PM   #1
crackling audio
On using the nano today when playing back clips the audio had a crackling noise I shot at 180mbs i-frame emmbeded audio
Any ideas
Ian
Ian Thomas.
Thomas Video Productions
Ian Thomas is offline   Reply With Quote
Old October 28th, 2010, 01:55 PM   #2
On watching more clips aswell as the crackling peoples voices are in slowmotion????
Ian Thomas.
Old October 28th, 2010, 02:29 PM   #3
Dear Ian,
How was the audio provided to the nanoFlash, HD-SDI or via the 3.5mm Analog Audio Input?
What type of audio was provided, mic or line.
Where you using over and under-cranking?
Where you recording MOV, MXF or MPG.
Did you monitor the audio during recording via the headphone jack.
Was the nanoFlash securely mounted to your camera, or was it separate?
Dan Keaton
Augusta Georgia
Old October 28th, 2010, 02:46 PM   #4
Hi Dan
1 HD-SDI
2I INTERNAL MIC
3 NO
4 MOV
5 NO
6 CONECTED VI HAWKS-WOOD ADAPTER
thanks Dan
Ian Thomas.
Old October 28th, 2010, 04:29 PM   #5
Dear Ian,
Thank you, that helps.
Since the audio was sent to the nanoFlash as audio embedded in the HD-SDI stream we know that the camera is primarly responsible for the audio,
The audio will be processed by the camera, then digitized, then sent digitally over HD-SDI, with the nanoFlash stuffing the digital audio into the recording along with the video. There is little chance of the nanoFlash, as far as I know, of introducing crackling audio, as we do not manipulate the audio samples.
Firmware release 1.6.29 has been thoroughly tested by us and in the field and it would be highly unlikely that our firmware to process the digital audio and put it into the very widely used ".MOV" file type would be at fault.
What concerns me is your comment: "On watching more clips aswell as the crackling peoples voices are in slowmotion???? " I do not know what would cause slowmotion in audio.
If you were over or under-cranking, then I would have different answers.
May I suggest a test?
Setup your camera as before.
Monitor the headphone output from your camera and listen for clean audio.
Monitor the headphone output from your nanoFlash and listen for clean audio.
Then playback from the nanoFlash and listen for clean audio.
7. In the nanoFlashes audio menu, was it set for 2 Channels of Audio?
Dan Keaton
Augusta Georgia
Old October 29th, 2010, 02:26 AM   #6
Thanks Dan
First the crackling appears on both my EX1+3 both audio from the cameras monitered vi headphones is ok
Just done a test with the EX3 and nano the audio recorded on the nano is slowmotion with some crackle
on the card in the camera is fine
The camera is recording at 1080 / 50i on the nano the audio is set to IN EMBEDDED REC CHANNELS 2 and MONITER CHANNELS 1+2 1080i 50 at 140mbs
Ian Thomas.
Old October 29th, 2010, 02:37 AM   #7
firmware 1.6.29
Hi Ian,
It sounds like you maybe running an old firmware on the NF. Would you please confirm that you have installed 1.6.29 from CD - Downloads | Convergent Design | Professional Video Recorders and Converters
If you do have the latest firmware.., well as you said your NF could be troubled...
Cheers
Luben Izov is offline   Reply With Quote
Old October 29th, 2010, 02:55 AM   #8
thanks Luben
I only bought the nano 2wks ago and no i have not downloaded any upgrades i though mine was the new one, how do you find out if it has the new upgrade and i have downloaded the new one on to my computer but am a bit wary of making things worse
Ian Thomas.
Old October 29th, 2010, 03:00 AM   #9
Two weeks is very new.... go to Settings/About and look for Firmware 1.6.29 - any other has some bugs that have be resolved with 1.6.29
Please advise
Cheers
Old October 29th, 2010, 03:13 AM   #10
Luben
Can't seem t find settings got System, Video, Audio
Ian Thomas.
Old October 29th, 2010, 03:17 AM   #11
Hi Ian,
It is 2 AM in my world here and I need to get out of this office and go to bed. If you don't come with some conclusion about the firmware, Dan would be able to help you probably in about 2-3 Hours from now. I hope that you have an old Firmware installed (old stock) and when you flash the NF everything would come in place. Good luck Bro, I'll check some time later today how did you do with Dan.
Cheers
Old October 29th, 2010, 03:18 AM   #12
Sorry Ian, I guess I said Settings instead of System - go to System/About
Old October 29th, 2010, 03:19 AM   #13
ok thanks for your help
Ian
Ian Thomas.
Old October 29th, 2010, 03:22 AM   #14
Luben
Found it the firmware is 1.6.29
Ian Thomas.
Old October 29th, 2010, 03:28 AM   #15
Glad you did Ian!
Dan will take care from here for you. I would suggest Read the manual (it takes 15min) check your NF settings again with the manual and be ready for an "interrogation" ;-) from Dan. If he can't help you with bloging he would probably call you and resolve the problem if is resolvable over phone.
Good luck Ian
Cheers
