No need for Gemini on F3? at DVinfo.net
Convergent Design Odyssey
Old March 31st, 2011, 02:01 AM   #1
Although announced as a perfect match I still wonder if the F3 shall be worth the Gemini 444 according to its native resolution.
I read an article about the native sensor used for the F3. It says as follows:
"The CMOS sensor in the F3 has 1220*690 pixels in Green and 610*345 pixels in Red and Blue
This should work for 4:2:0 but curtainly not for 4:4:4. You'll get a great sensitivity and dynamic range. Also better S/N ratio and minimal aliasing. There is slight disadvantage in sharpness and resolution."
I would conclude that the Nanoflash will be good enough for the F3 and you gain too little (2 bits depth) by using 444 recording. Unless I go for the S-Log option, I would not need a Gemini-like recording device.
Is this a rational conclusion?
Ron Aerts is offline   Reply With Quote
Old March 31st, 2011, 09:29 AM   #2
Re: No need for Gemini on F3?
I don't think those resolution values are accurate. The resolution of the imager exceeds 3k.
From what I've read the camera may not completely resolve 4.4.4 but it will be close.
http://www.LandYachtMedia.com
Old March 31st, 2011, 10:22 PM   #3
If you look at the recently released BBC report, its Zone Plate test makes it appear as though there are an even number of R, G, B pixels on the sensor.
look at page 10.
http://thebrownings.name/WHP034/pdf/...ony_PMW-F3.pdf
Here is the thread about this report http://www.dvinfo.net/forum/sony-xdc...bc-report.html
If you read the entire report, you will see glaring mistakes; however, the Zone Plates cannot lie.
Personally, just the S-Log output is worth it not to mention the ability to record 1080 60p.
Steve Kalle is offline   Reply
