distorted audio at DVinfo.net
Convergent Design Odyssey
Old May 16th, 2011, 01:56 PM   #1
distorted audio
Hi, I am at an event recording with the Nanoflash out of a SDI switcher.
I'm taking the audio into the 3.5 mm input
Out of the Mackie 1604 taking aux 1 out.
whether I have it in "1 channel balanced or 2 channel unbalanced stereo" it sounds distorted. Does not seem to matter where the gain is set. Just lower or louder.
What am I over looking? James
James Redmond is offline   Reply With Quote
Old May 17th, 2011, 10:50 AM   #2
Sponsor: Convergent Design
Re: distorted audio
Hello James,
Do you know what the db is set for on the Mackie 1604 taking aux 1 out, since the nanoFlash can only adjust the level so much, also do you have the latest firmware 1.6.248, so you have an adjustable range (compared to previous firmware),
Also note that the audio bars will indicate the current levels, Which should be ideally, -20 db (NTSC Standard), or -18 db (Pal Standard)
This may take turning down everything on the nanoFlash then turning down everything from the Mackie 1604 taking aux 1 out.
Hope that Helps
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply
