-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   NTFS and FAT32 drives (https://www.dvinfo.net/forum/convergent-design-odyssey/501684-ntfs-fat32-drives.html)
Robin Probyn October 16th, 2011 06:58 PM
Can someone explain the difference.. pro,s/cons..and how it would relate to Nano recordings and using a mac for down loading footage to a mac formatted HDD..
Thanks again
Chris Medico October 16th, 2011 10:25 PM
Re: NTFS and FAT32 drives
NTFS is a more modern and robust file system. It supports very large file sizes.
FAT32 works on just about every computer on the planet made in the last 25 years. It has a 4Gig size limit per file.
The reason you don't find NTFS in more places is because of the licensing issues with Microsoft.
Eric Lagerlof October 16th, 2011 11:02 PM
Also Macs can read Windows NTFS drives but cannot write to them. They can only write to FAT32. (3rd party software may make a exception to that.)
Gints Klimanis October 17th, 2011 03:04 AM
Will Nanoflash support UDF?
Also, with firmware earlier this year, i was caught in a recycle loop. During firmware upgrades, I'd like to save a trip back to the computer with a Nanoflash boot option that allows a choice between formatting a CF card or upgrading firmware. On one expedition in which I did not have access to a computer, I didn't format one of my large CF cards right after the Nanoflash firmware upgrade and couldn't use it at all because it contained the firmware upgrade folder. I was stuck in a reboot loop miles away from a road.
Piotr Wozniacki October 17th, 2011 04:43 AM
Very good point, Gints!
Dan Keaton October 17th, 2011 08:38 AM
Dear Gints,
It would be nice to support UDF.
However, there is a tradeoff. If one experiences any type of problem while recording a very large file, then the entire file can be lost. If one breaks it up into smaller files, then one minimizes their risks.
We should give you the option to format the card that contains the firmware update folder.
Gints Klimanis October 17th, 2011 02:17 PM
Thanks, Dan. That format after firmware upgrade is a useful convenience function to keep some users out of a jam. Another way : to allow a choice menu to boot the Nano to boot without firmwareupgrade, and perhaps that may be cheaper for CD to develop and test.
Menu : reboot,upgrade, skip upgrade (or start without upgrade)
Andy Mangrum October 27th, 2011 09:03 AM
Hello Gints,
Thank you for your suggestion,
As for the Copying to a Mac compared to a PC, Snow Leopard and Lion are formatted as HFS, Which Works just fine as does NTFS, the major difference being taking a Mac Formated HFS drive to a Windows machine, and being able to recognize it, as well as the File Sizes will appear slightly different.
Typically if you are backing up to an External Drive, regardless of what Type of Machine you are using (Windows or Mac) if you format that drive as a Fat 32 then you should have no issues with any Operating System, (Windows XP, 7, Mac 10.5,10.6, Linux etc)
Hope That Helps
Robin Probyn November 11th, 2011 07:29 PM
Sorry another question re FAT 32.. if copying a file over 4GB.. to a FAT HDD.. the file will be split..? or wont copy over?
Dan Keaton November 12th, 2011 12:38 AM
Dear Robin,
If you are attempting to copy a file larger than 4 GB to a FAT 32 Drive, you will be unable to copy the file.
Note: I am assuming that you are speaking of a file other than a nanoFlash file, since our files, and our our utilities such as our file converter automatically handle this automatically for you.
Robin Probyn November 12th, 2011 02:53 AM
Hi Dan
Well talking generally .. but I would be using my nanoflash.. so I take my CF card from the nanoflash and down load to a FAT 32 formatted HDD.. everything will be ok.. is that because the nanoflash separates the files as it records them?.. if they go over 4GB..
A client has asked about wether they can view MXF files from the nano on some avid software on their laptop.. I,ve asked in a separate thread.. do you know about this at all?
Ordered and awaiting the delivery of remote cable .. !
Can I down load from a card reader ..via my MBP.. to a mac formatted ext HDD and a Windows formatted ext HDD at the same time.. using shotput pro..?
Thanks again..
Mike Peter Reed November 12th, 2011 05:36 AM
Another important difference I don't see mentioned (and I only skimmed so apologies if someone did already mention), is that FAT32 is not journalled, but NTFS is journalled.
Journalling theoretically makes NTFS more robust than FAT32 in the case of file corruption. In practice, using removable media, I'm not so sure that's a huge advantage (or makes any practical difference) but I'll always opt for NTFS because it can deal with files over the FAT32 2GB/4GB limit.
There's options available to Mac users for read/write NTFS - personally I use Tuxera on Lion.
Tuxera NTFS for Mac | Tuxera
Of course, most devices use FAT32 as a defacto standard, my Panasonic SD900 and Nagra LB included. It appears the Nagra extends it's own journalling system on top of the FAT32.
ZFS for all one day? ZFS - Wikipedia, the free encyclopedia - it reportedly almost replaced HFS+ as the default filesystem for Macs a few years ago.
Dan Keaton November 12th, 2011 11:52 AM
Originally Posted by Robin Probyn (Post 1696498)
Hi Dan
1. Well talking generally .. but I would be using my nanoflash.. so I take my CF card from the nanoflash and down load to a FAT 32 formatted HDD.. everything will be ok.. is that because the nanoflash separates the files as it records them?.. if they go over 4GB..
2. A client has asked about wether they can view MXF files from the nano on some avid software on their laptop.. I,ve asked in a separate thread.. do you know about this at all?
3. Ordered and awaiting the delivery of remote cable .. !
4. Can I down load from a card reader ..via my MBP.. to a mac formatted ext HDD and a Windows formatted ext HDD at the same time.. using shotput pro..?
Thanks again..
Dear Robin,
I added numbers to your questions.
1. The nanoFlash automatically creates files that fit into the 4 GB limit, so there is no problem.
And we have tools to stitch them back together, if desired, but this is usually not required.
2. For Avid, for older versions, then can view 50 Mbps Long-GOP, and all I-Frame Only flavors.
For the newest vesions, all flavors are supported.
The Sony XDCam Clip Viewer, version 2.10 is a great viewer for our MXF Files.
3. Great.
4. I am sorry, I do not know. Others should be able to answer that question.
Robin Probyn November 13th, 2011 04:36 AM
Hi Dan
Thanks as ever. is Avid ok with 35 Mbps Long GOP.. 1080/50i or 25p.
35Mbps HD would be better "quality" than SD .. shot on a 2/3 inch camera with exp glass.. ?
Thanks again
Dan Keaton November 13th, 2011 07:53 AM
Dear Robin,
This is the same as XDCam EX, so if your Avid supports EXCam Ex then our files will be supported.
Your second question is a subjective call.
The nanoFlash can record SDI (SD-SDI) using IMX-50, a very high quality SD format.
The nanoFlash can also record IMX-30 and IMX-40.
To answer your question:
I feel that, generally, one may be happier with HD at XDCam EX specs, 1920 x 1080, 4:2:0, 35 Mbps, Long-GOP, Variable Bit Rate as to recording SD with much lower resolution.
But, if the client wants SD, the client should get what he wants.
Robin Probyn November 13th, 2011 06:23 PM
Hi Dan
Ok thanks again.. so 35Mbps is 4 2 0.. . 50 mbps is minimum for 422...
Thanks again
Dan Keaton November 13th, 2011 06:36 PM
Dear Robin,
Yes, that is correct.
