SSD card error code at DVinfo.net
Convergent Design Odyssey
Old May 1st, 2015, 11:22 PM   #1
SSD card error code
Can someone help translate the error code "Could not recover SSD 2 Err:146341894", and "Unsuccessful safe eject SSD2, Err:2147942407"? On a recent shoot an asst. had probably pulled the card out without going through the proper eject process. The card cannot be rebuild within Odyssey 7Q+. Can it be salvaged with other methods?
Brian Lai is offline   Reply With Quote
Old May 7th, 2015, 07:16 AM   #2
Sponsor: Convergent Design
Re: SSD card error code
You should re-insert the SSD into the Odyssey and attempt the rebuild process again. Sometimes it can take a few passes to completely correct the issue. If it remains a problem, please contact us at cdsupport@convergent-design.com.
Mitch Gross is offline   Reply
