Was AE used to do this...? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old February 4th, 2008, 04:04 PM   #1
Hello,
I currently have AE7 and wanted to know if AE was used to do the headshot images and titles spinning/floating in on the video here: http://www.earthquakeproductions.net/main.html
If so, did they use presets or simple rotation keyframes? Also, the title text looks to be 3D. How can I do this in AE7 (soon to be AE3)?
Thanks Much!
Troy
Troy Davis is offline   Reply With Quote
Old February 4th, 2008, 05:01 PM   #2
The spinning can be done simply by roto the subject, turn the layer to a 3D layer and then rotating on the Y axis.
The titles were probably made with ZaxWerks' ProAnimator, excellent package, worth every penny. See http://www.zaxwerks.com
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old February 4th, 2008, 06:00 PM   #3
I think there's a plug-in for AE called 3D invigorator that can produce 3D text within AE. You can also use BorisFX's Boris Red or Blue for 3D text as well, or a full-blown 3D modeling/animation package if you're feeling adventurous!
Shawn McCalip is offline   Reply With Quote
Old February 4th, 2008, 06:11 PM   #4
Thanks guys. I actually have ZW's package, but find it difficult to sync w/ AE. I'm sure with more practice I can make it work.
Old February 5th, 2008, 10:33 AM   #5
The video doesn't work for me, but if you are looking for text presets look in the bridge! You can access it in after effects up top somewhere, animation>animation presets (I think, I don't remember exactly)
The bridge will open, and you can select text transitions where you'll find lots of crazy little animations to apply to your text layer.
Aric Mannion is offline   Reply With Quote
Old February 5th, 2008, 07:53 PM   #6
Here you go....
http://www.motionworks.com.au/traini...ning_video.htm
Old February 6th, 2008, 01:40 AM   #7
The video looks like something done in Motion rather than AE.
Brian Keith Moody, Writer / Director
Canon XH-A1 - PowerMac G5 - Final Cut Pro - Shake
Brian Keith Moody is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
