8 bit or 16 bit? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old July 23rd, 2008, 03:03 PM   #1
8 bit or 16 bit?
I am importing some clips from Premiere (Animation Codec MOV on Mac) and want to know if I should be setting the compositions to 8 bit or 16 bit. What's the difference? And if I worked in 8 and need to switch to 16 for better quality, do I need to start over?
Cinematography Site
Nathan Quattrini is offline   Reply With Quote
Old July 24th, 2008, 09:20 AM   #2
if you gonna make heavy color corrections is better to go to 16 bits, otherwise 8 bits is fine (i´m assuming that your original footage is 8 bits, like DV or HDV or so)
You can switch back and forth 8 o 16 whenever you want.
Martin Chab is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
