Effects in Motion at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old January 22nd, 2009, 03:34 PM   #1
Effects in Motion
New to Motion. Can any Motion gurus tell me how to do a simple effect. I just want to make a red line go across the screen against a black background.
"Get Er Done!!!"
G. Lee Gordon is offline   Reply With Quote
Old January 22nd, 2009, 08:15 PM   #2
After Effects? In an empty comp create a black layer. That's your background. Then make a red solid layer and place it above (in front of) the black layer. Apply a mask over the red solid layer the size and shape you want. Using keyframes on the timeline you can animate its position.
Best suggestion I have is spend time with the product and also here.
If you're not using AE, you'll have to tell us your software.
Old January 23rd, 2009, 09:52 AM   #3
Sounds like Motion IS the software.
Open motion. Press P, or just go to the paintbrush icon in the "Create" set.
Draw a line.
Play it back and it should be auto-animating. Change the duration of the write-on behavior that was created, and change the properties of the stroke to fit your needs. Press F7 for the HUD or just use the inspector.
Mike Wilkinson - Apple Certified Pro Motion/FCP, HVX/DVX Operator
www.wccnet.edu/flashvideos | www.wilkinsonvisual.com
Mike Wilkinson is offline   Reply With Quote
Old January 23rd, 2009, 06:28 PM   #4
Oops. Sorry.
Old January 23rd, 2009, 10:42 PM   #5
Yes, I am using Motion... I tried the paintbrush feature, but can;t get a straight line.
"Get Er Done!!!"
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
