How to create 3D logo? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old February 12th, 2009, 04:33 PM   #1
Hi All,
I have a company logo and I need to make it into 3D in Vegas. Is it possible?
I also have Ulead cool 3D can I do it with cool 3D? If so how?
Please let me know.
Matthew
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old February 12th, 2009, 08:45 PM   #2
Can't speak to Vegas since I don't use it, but Cool 3D will do nothing but make you nuts. I tried doing precisely what you want to try years ago and I'm still recovering. (grin)
I did my current logo in After Effects. Compared to AE, Cool 3D is like working with stone knives and bear skins.
Old February 15th, 2009, 07:40 AM   #3
don't know cool 3d but I'm sure it will allow you to extrude your flat artwork.
Basically if your logo is in vector format and straightforward (ie standard text) you import into a 3d package, look for the tool that 'extrudes' or basically pulls out the vector points in Z space to a depth that you determine - then most will have fillet and cap options on the extrude which will allow you have chiseled edges of which the thickness is determined by numbers you define
again - this is assuming your logo is an easy translation in 3d space. If it has, for example, a circle in it you may want to create that part of the logo from 3d primitives such as a sphere and extrude the other parts that just need thickness
then you'd animate how you wanted it to move etc and import the alpha channeled artwork into something like AE - or straight to vegas I imagine
hope that makes sense
trish
Trish Kerr is offline   Reply With Quote
Old February 15th, 2009, 03:32 PM   #4
cool 3d allows you to make a 3D logo from any b&w picture.
it does not allow for complex shape (just flat extrusion) but is ok for most work.
Old March 1st, 2009, 12:13 AM   #5
Zaxwerks 3D Invigorator
Works great at extruding and animating any 2D vector art. You do need the original document as an Illustrator file to begin with, but once you get the hang of it you can turn things 3D quickly. I use it as a plug-in in After Effects.
Paul E. Coleman is offline   Reply With Quote
Old March 2nd, 2009, 01:17 PM   #6
Cool 3d Production Studio ($130 new/$80 upgrade) has a lathe tool that comes in pretty handy for creating custom objects. Also it can import 2d emf and illustrator documents. It's okay for something quick, but if you're looking for accuracy then you might as well forget it.
It's not much, but I made the globe logo in this spot with Cool 3d Production studio
http://www.casscomm.com/advertising/...ill_test01.wmv
John C. Plunkett is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
