Pulldown to Premiere? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old February 28th, 2009, 01:05 PM   #1
I'm curious as to whether or not this works:
If I import a Canon HF100 AVCHD mts file into After Effects, and "re-interpret footage" to extract the true 24p stream from the 60i that it piggy-backs on, and then export directly to Premiere Pro, does it keep that effect, or is it lost in the transfer?
The 24pf files are converted in the camera via pulldown and I'm interested in converting them back to their true 24p. After I reinterpret the files, I want to send them directly to Adobe Premiere Pro to work with. I'm just wondering if I do that, will the reverse pulldown remain with the file?
"Make the most of yourself, for that is all there is of you." R W Emerson
RED ONE MX | 5DmkIII | SD744T | SD442 | Sennheiser MKH416 P48
Brian Maurer is offline   Reply With Quote
Old March 2nd, 2009, 01:27 PM   #2
Anyone? I'm not sure if this is working and was wondering if anyone used this technique?
Old March 6th, 2009, 02:10 PM   #3
Should work.... in Premier after the footage is ingested look at the properties...
they should indicate 24p... if not then you will have to output from AE and then import
into Premier... just an added step...
Ray Bell is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
