After Effects render/export problem at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old July 20th, 2009, 11:10 PM   #1
I'm exporting a Magic Bullet Looks project from After Effects and when I render the clip the exported quicktime movie is split. Top half green, bottom half rendered. (see attached screenshot). I'm totally blundered on this one.
Help!
After Effects render/export problem-picture-1.png   After Effects render/export problem-picture-2.png
Christopher Onstott is offline   Reply With Quote
Old July 23rd, 2009, 05:24 AM   #2
I've had something similar happen to me as well, except it is more of a flicker then a split, but this only occurs when I right click on my edited clips in Premiere and goto replace with After Effects Composition or if I simply copy and paste my Premiere timeline into After Effects. The only solution for my problem is saving the After Effects project, closing it and reopening it.
For your problem though, have you tried getting updated drivers for your video card? Also try to export a couple PNG/PSD frames just to make sure it's not your Quicktime Codec that could be screwy. Also don't know if this would cause it, but make sure your fields are set properly (ie if you shot progressive, set it for it under the File->Interpret Footage or right click on the file in your project window).
Motion Blur Studios - Canon XL H1, XL2, nanoFlash, 2xFS-4 HDs, Custom 9TB RAID 10 Array HPT RocketRaid 4320, GeForce GTX 480, Adobe CS5 Production Suite
Jarred Capellman is offline   Reply With Quote
Old August 10th, 2009, 09:24 AM   #3
solution?
I have the same issue and I'm wondering if anyone has an explanation or solution?
Frank Yoklins is offline   Reply With Quote
Old August 14th, 2009, 05:30 PM   #4
It looks like a field order, interlaced, progressive confusion.
David Merrill is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
