Green Screen Help at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old October 5th, 2016, 01:55 PM   #1
Green Screen Help
I am trying to remove this small outlet behind this individual but I can't figure out how. Any suggestions?
Brock Burwell is offline   Reply With Quote
Old October 5th, 2016, 03:25 PM   #2
Re: Green Screen Help
What software are you using? If the subject never crosses that part of the image, you can probably just crop it out. If you did this in After Effects, just use a mask set to subtract drawn around that corner of the frame.
Edward Carlson is offline   Reply With Quote
Old October 6th, 2016, 06:40 AM   #3
I'm using Final Cut Pro
Old October 6th, 2016, 06:44 AM   #4
Use 4 point garbage matte.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
