Stabilisation via Camera Match Move |*Apple Motion at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old March 11th, 2018, 08:39 AM   #1
To stabilize a clip, I analysed the movement with three trackers, and applied a camera matching the move.
It worked fine, preview was good. But after export, I encountered frames with ghosting artifacts. I have absolutely no idea on this. It is definitely not motion blur and there is neither frame blending nor optical flow applied... as I said everything was fine in the preview. Frame rate of clip and project are the same.
Ideas, anyone? Many thanks in advance!
Jörg Frommann is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
