"REWIND" effect for After Effects or FCP. at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old August 16th, 2006, 02:14 PM   #1
I am looking for some sort of plugin that will recreate the VHS rewind effect for After Effects or Final Cut Pro.
Anyone heard of something like that?
Matias Baridon is offline   Reply With Quote
Old August 16th, 2006, 08:37 PM   #2
Couldn't you just record to VHS, and then record that back into FCP?
Most (but not all) DV cameras can act as a convertor, so you can print to VHS tape, and then use capture now to capture from the VHS tape (disable device control).
That would give VHS quality though, with the analog funkiness and all (is it what you want?).
2- A different approach would be to use the time remapping / velocity envelopes. (Can't remember what they were called.) It's in FCP.
Old August 16th, 2006, 08:42 PM   #3
I like the VHS idea, especially on the old 2-head players!
Nick Weeks is offline   Reply With Quote
Old August 29th, 2006, 09:55 PM   #4
I thought there must be a plugin effect that would do the VHS rewind effect without having to actually do it with a VHS.
I didnt try it yet, but I think the VHS will give a strange look, for the image quality of the rewind will be notoriouslly reduced compared to the rest of my footage shot in Beta.
Old August 30th, 2006, 09:31 AM   #5
how about taking black (or some color) video, capture yourself rewinding the video on VHS to FCP, then just overlay (key) the rewind effect on your video?
Old August 30th, 2006, 10:49 AM   #6
capturing it would be difficult. i know my analog capture setup captures different than you expect when the vsync goes crazy as it normally does when rewinding VHS.
Chris Chang is offline   Reply With Quote
Old September 2nd, 2006, 03:17 AM   #7
I know Tinderbox 3 has some 'tv effects' but I don't think an actual 'rewind' plugin. But is has a function called 'bad tv' which looks a bit like a rewind function I think. If you combine that plugin in combination with reversing the footage, I might look like that, even though I have never tried it.
http://www.thefoundry.co.uk/pkg_plug...2-3FCC03D7530A
On that page you can see a still of that effect beeing used.
www.wanah.nl
Djee Smit is offline   Reply With Quote
Old September 2nd, 2006, 07:50 AM   #8
I don't know the exact definition of this "rewind" effect is, does it require distorting the footage? If not, I would just reverse the footage and apply a speed change to it.
What exactly are you looking for, you have me interested now?
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old September 4th, 2006, 10:48 PM   #9
I am looking for the typical horizontal lines that appear at the top and bottom of the video when you rewind or fast forward and old VHS tape... I really dont know any other way to define it, but when you rewind a VHS tape, you do not get a smooth reverse movement,, but the image suffers some displacement, as well as some "noise".
Old September 5th, 2006, 06:04 AM   #10
Gotcha! Thanks.
Mike
Old September 5th, 2006, 07:00 AM   #11
are you applying this to SD or HD video?
Old September 5th, 2006, 10:25 PM   #12
for this case i was working with SD.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
