-   Digital Compositing and Effects (https://www.dvinfo.net/forum/digital-compositing-effects/)
-   -   Suggestions for a small inhouse render farm? (https://www.dvinfo.net/forum/digital-compositing-effects/84168-suggestions-small-inhouse-render-farm.html)
Eric Kome January 17th, 2007 05:29 PM
We just finished a big project with a lot of compositing in AE and big renders in Compressor and FCP. For a while we had QMaster set up on about 6 other machines here, and it worked great with Compressor (though couldn't get it to work with AE or FCP). Then, it inexplicably just stopped working, and could not get it working again. arg!
We're anticipating some other larger projects coming in the future, and would like to set something up to help utilize our other Macs to help during off hours. this "5 days remaining" in the render window just aint cool.
We're using MacG5s duals and quads, OSX, mostly using AE, Compressor and FCP, but just getting into Shake as well. Any suggestions on software/hardware to help us would be fantastic! thanks!
Ken Hodson January 17th, 2007 06:28 PM
There is a program called Gridiron for network rendering in the PC AE. Not sure if it comes with Mac version. There also is another ad-on that implements dual core usage when used in a network render. I can remember the name right now.
Conor Ryan January 18th, 2007 04:42 AM
Gridiron is best for AE, but AE can network render for free. You have to install the AE render engine on all machines and set it up for network rendering. There are plenty of resources out there for doing this, including the Adobe website (see their fora, and resources pages). The network render can also be scripted within AE, try looking at www.aenhancers.com for appropriate scripts (there are many other interesting things there).
For Shake, you're already on the right track with Qmaster. You could even look into XGrid for other applications, if all else fails.
Since you're on macs, you should consider a dedicated farm of minis, which for $:Mhz ratio are best.
Eric Kome January 19th, 2007 10:57 AM
thanks for the replys. what would be nice, is to have one software/system that could work for all of our rendering in all of our programs... i'll look into that XGrid too, as this Qmaster has worn out my patience.
i do recall someone on here (may have been you Conor) using the minis as a render farm. it's a great idea...
