Stretching Animated Background in After Effects! at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old February 26th, 2007, 09:35 PM   #1
Hi Pros!!
I have an animated background which I want to use for my Chromakey however, it is only 1 minute long.
Can someone please tel me as how I can stretch it to the same length as of my movie footage?
I don,t want it to be slow motioned.
Any thoughts?
Matthew
Matthew Amirkhani is offline   Reply With Quote
Old February 27th, 2007, 08:01 AM   #2
Well, if you stretch it, it will be slow motion. So, about the only thing to do is cut it up and reuse portions of it, have two instances of it, reverse one and place on the end of the first one so that it "bounces" from beginning to end to beginning. Or, cut out portions of it that are still, and lengthen those parts.
That's all assuming it's a self-contained movie, if it's something else you might be able to go into its settings. If it's an After Effects compositions you can move the keyframes around, lengthen certain layers, and so on. Same goes for Motion, Shake, et al.
Conor Ryan is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
