Text with inside footage at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old April 28th, 2007, 08:37 PM   #1
I need to have some text overlay some footage so that the footage is only revealed inside the letters of the text. I set the text as a luma matte and that does what I want except that it makes the colors in the BG footage desaturated. What am I missing?
B-Scene Films
Shaughan Flynn is offline   Reply With Quote
Old April 28th, 2007, 10:34 PM   #2
What software are you using?
James Huenergardt is offline   Reply With Quote
Old April 29th, 2007, 10:54 AM   #3
Oh yeah heh - After Effects 7 pro.
B-Scene Films
Old April 30th, 2007, 09:28 AM   #4
Where is your text coming from? AE? Photoshop?
Old April 30th, 2007, 09:41 AM   #5
if the text is floating in space (no background color on it), switch to an alpha matte, that'll use the shape of the letters rather than the brightness.
Web Youtube Facebook
Cole McDonald is offline   Reply With Quote
Old April 30th, 2007, 01:12 PM   #6
The text is created in AE. Only the luma matte shows the footage thru the text. The footage turns out monochrome =/
B-Scene Films
Old May 2nd, 2007, 08:51 AM   #7
The trick turned out to be that I needed to set the luma mask on the footage and have it use the text as a mask - not the other way around.
B-Scene Films
Old May 2nd, 2007, 09:06 AM   #8
glad you figured it out...these things are frustrating when you KNOW something should work and it won't cooperate.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
