What can I buy to speed up rendering in After Effects? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old May 11th, 2007, 01:42 PM   #1
I do a lot of After effects work. Rendering seems to be taking up a lot of my time. Is there anything hardware/software I can buy to speed up rendering of complex projects?
Anyone use Gridiron Nucleo Pro? Is it worth it?
Tyson X
Tyson Persall is offline   Reply With Quote
Old May 11th, 2007, 01:46 PM   #2
I'm on the AE Mailing List and Nucleo screams...You can check out the archive or their web site.
Jeff Butler
Butler Films
Jeffrey Butler is offline   Reply With Quote
Old May 11th, 2007, 02:43 PM   #3
Out of the box, you can setup the after effects render engine on other computers to distribute the load and drop your render times. Nucleo is a good solution if you are stuck to one computer.
software engineer
Jad Meouchy is offline   Reply With Quote
Old May 15th, 2007, 06:27 PM   #4
Check out this script as well, which runs multiple instance of the AE Render engine to speed up renders:
http://www.aenhancers.com/viewtopic.php?t=544
To live a creative life, we must first lose our fear of being wrong.
- Joseph Chilton Pearce
Paul Cuoco is offline   Reply With Quote
Old May 18th, 2007, 09:59 AM   #5
AE CS3 or Nucleo are your best options. CS3 runs much faster on multi processor systems.
Steve Benn is offline   Reply With Quote
Old May 19th, 2007, 08:50 PM   #6
I am on an Dual Opteron 270 system. 4 physical cores.
Tyson X
Old May 23rd, 2007, 05:24 PM   #7
Does AE take advantage of the Quad Core CPU's?
Andrew Clark is offline   Reply With Quote
Old May 23rd, 2007, 06:16 PM   #8
CS3 will, but not AE 7 or earlier.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
