slowmo and jitter at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old June 12th, 2007, 08:59 AM   #1
slowmo and jitter
Hi, I tried this slomo technique http://rarevision.com/articles/slow_motion.php
it worked very well but I got flickering.
Should I do anything in the process to eliminate this flickering?
Sassi
You can see a sample here http://stage6.divx.com/user/sasi_yaa...ONEY-BUZZARD-2
the clip shows migrating raptors.
that is a 17MB file on stage6 so you will need a Divx codec (available for download there).
Sassi Haham is offline   Reply With Quote
Old June 12th, 2007, 07:55 PM   #2
The jitter on the top and bottom is something that can happen. Depending on what program you use there are ways to eliminate it. I do my slow mo renders in after effects and it has a simple check box to interpolate lines and fix the problem. If you wanna do it low tech just scale it up a bit. Like 2% bigger. Shouldn't be an issue.
Have fun
Alan James is offline   Reply With Quote
Old June 12th, 2007, 10:30 PM   #3
check box
Thanks Alan, where in the process I find this check box ?
Old June 12th, 2007, 11:17 PM   #4
Here is a really good explanation I have written up before about the subject.
http://www.dvinfo.net/conf/showthrea...hlight=slow+mo
If your using After Effects 7 it should be pretty easy to follow.
Have fun
Old June 13th, 2007, 01:11 AM   #5
Thanks again,
This is exactly what I (think) have done.
Does the "preserve edges" check box eliminate the flicker?
Sassi
Old June 13th, 2007, 06:55 AM   #6
Yeah, its suppose to. It interpolates scan lines. Should clear it up. I have found that at time I still get a little jitter though, but not nearly as much as you had in ur comp. So if you still see jitter another solution is to apply a 2 pixel vertical directional blur to your comp. You will loose some detail, but the detail is what is causing the jitter. Unfortunately using this method there are always trade offs.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
