Cineform footage problems in AE at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old June 19th, 2007, 08:01 AM   #1
Hi im new in HDV. Im importing Cineformīs files into AE and even i do interpret footage (AspectHD aviīs exported from a 1.33/1440x1080 project in premiere) and open a 1440x1080 composition, i get a wrong pixel aspect ratio (ive tried all the possibilities, no way). i only get the right image aspect if i make a 33% x-axis upscale...
And also i have problems to make RAM previews, just a few seconds and is like RAM is finished. is that possible? (i have 2g and i have 70% or RAM usage in preferences)
Please some help!
Hernan Vilchez is offline   Reply With Quote
Old June 19th, 2007, 04:46 PM   #2
CTO, CineForm Inc.
Wecome to HD compositing -- it uses a lot of memory. AE will only preview with 1.33:1 pixel aspect if you tell it to -- use the view button called "Toggle Pixel Aspect Ratio Correction."
Old June 20th, 2007, 03:33 PM   #3
Thanks David, nice little buttom...
any suggestions for the RAM issue? is 2g not enough to composite in HD? would 4g be enough (since i work with XP 32)?
or should i forget compositing till i get XP/Vista 64?
Old June 20th, 2007, 03:47 PM   #4
CTO, CineForm Inc.
AE can only buffer about 1GB under 32-bit Windows, that is around 5 seonds in 8-bit and 2.5 second is 16-mode for 1440x1080 HD. Try previewing at 50% or smaller.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
