Exporting text made in AE to Vegas at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old June 19th, 2007, 05:22 PM   #1
Hi all,
Here is something I haven't tackled with in either program. The text engine in AE offers so much more compare to Vegas that today I decided to create my texts in AE and export it.
Problem is I export the background color as well. I tried a black background color but when I import it into vegas I need to set it's track to "add". In the process I lose the drop shadow and the outline around the letters.
Is there anyway that I could create a text in AE with only a transparent background. I tried exporting using all sorts of settings, premultiplied, alpha only etc...
None of them worked, I always end up losing the drop shadow applied to the text and the black outline is replace by a white one.
Thanks guys
Phil
Phil Gosselin is offline   Reply With Quote
Old June 19th, 2007, 10:40 PM   #2
In After Effects, make sure you export the text with an alpha channel, with "straight" alpha. The animation codec should support an alpha channel.
In Vegas, make sure the clip is interpreted to have "straight" alpha/transparency. Look in the properties in the clip, go into the second tab, and find the straight option. You can copy and paste event attributes to copy this to other titles.
Old June 20th, 2007, 09:23 AM   #3
Hi Glenn,
Nope, still no good results, I still have to set the track to "add" and I still lose the drop shadow and the outline, they both turn to white.
My background colour was white in AE.
I export from AE in DV uncompressed at 29.97 fps, a very common format. I also used QT with Mpeg4 full quality, still the same thing. I did notice that the DV adds a tiny grey tint so I will stick to the QT in mpeg-4.
Any other suggestions.
Old June 20th, 2007, 09:59 AM   #4
Phil
In your AE project click on the transparency icon, the one to the left of Active Camera, you should be able to see the transparency "checkerboard".
When you render fro AE select under the output module select "Lossless with alpha". then render. When you bring the file into Vegas you may need to right click, select properties, advanced, and at the bottom select Premultiplied and then set the color to white.
Jim
Jim Montgomery is offline   Reply With Quote
Old June 20th, 2007, 10:32 AM   #5
Hey Jim,
Thanks for thanks for your answer, now after trying what you suggested the problem is half solved, sort of...
The drop shadow and the outline finally stays through the process but now I have this white background I can't get rid of even after trying several compositing modes for the track.
I don't want to sound ungrateful but in my mind this is so simple, creating the simplest text animation in AE and exporting it Vegas, why then is it so damn complicated....
Anything else,
Thanks guys
Old June 20th, 2007, 11:29 AM   #6
Ok, you have it in a Veags timeline. Right click on the event, select the media tab, go down to the bottom and select premultiplied from the alpha channel drop down box. Change the color to white and hit OK, or close or whatever. You do not need to select any kind of compositing mode.
Be sure to have another event underneath that clip so you can see.
Jim
Old June 20th, 2007, 08:02 PM   #7
HI Jim,
I've already tried what you explained last but the solution was lying elsewhere.
Here is a step by step explanation
When exporting text to use as event in another here is how I now do it.
1: Use Quicktime with ---Animation--- codec , full quality
2: Set channels to : RGB + Alpha
3: Set Colors to: "Straight (unmatted)
Render
After importing (for this example I will use Vegas as a reference)
1: Right click on the event and go on properties
2: Go into the "media" tab
3: Set the "Alpha Channel" to "Straight"
That did it for me, the text appears just as if I would've created it in Vegas.
Thanks for all the pointers guys
Cheers
Phil
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
