B&H has the price of the TM700 set to $1,000.
The have the HS700 there now too, for $1399. That strikes me as a fairly pricey 240GB HDD. Funny thing is, the TM300 is a tad more expensive than the HS300 at B&H. Maybe the prices on the 700 will change before they actually start accepting orders.
I would always opt for the Flash version. Solid State media is much more reliable.
Nice cams; but how does one edit the 1080/60p footage?
Premiere with Cineform intermediate should work fine. Premiere CS4 may work natively - don't quote me on that though.
Media tanks like this can play back raw or edited 1080P60 H.264 and MP4: EGreat EG-M34A High-definition Network Media Tank (NMT) |
I've tested a clip from an HD2000 on Premiere CS4 natively and it works.
1080P60 H264 is Level 4.2 to decode you need at least SIGMA DESIGNS SMP8655. WD TV gen2 ok for 1080P60 H264 is Level 4.2. |
You'll find 9 native 1920x1080 60p files in this thread.
Panasonic HDC-HS700 & HDC-TM700 1080p60 cams - Page 5 - AVS Forum For playback on a decent Windows computer, you'll need Nero ShowTime. The Sony PS3 will also playback the files. The files are a little bit different than what's in Sanyo's camcorders. The PS3 plays them better. The bit rate is also a little higher. Still, just like the files from Sanyo's camcorders, Premiere Pro will also edit them naively. |
It's wrapped in m2t instead of mp4. I can confirm Sony Vegas 9 injests the footage absolutely fine.
Watch.Impress review of the TM700:
http://av.watch.impress.co.jp/docs/s...24_356414.html English Translated: Google Translate It took a while but better late than never. |
Questionable Math at Best
There's some argument that in-camera interpolation will yield a better result. That wouldn't be the case if you wrote out a 48-bit 3.1Mpixel TIFF or whatever, but given the limitations of the JPEG you're using, I'll bet there's an improvement. But all the way to 14.2Mpixel? Pretty dubious. There are certainly "marketing pixels" in there. All the single-sensor cameras have the advantage that, in still mode, they're basically using the same high resolution Bayer-style sensors used in the digital still cameras. Those sensors are a disadvantage for video, but an advantage for stills, where the extra spatial resolution is useful and the lower color information not so much. So Panasonic's thinking very consumery here and trying to keep that comparable on spec sheets. Of course, Sigma's been pulling off much the same story with their Foveon-sensor based cameras (single CMOS chips with three photo sensitive layers). I suspect anyone doing much still photography with any video camera isn't concerned with the best quality of still photos anyway.. they're printing 4x6 prints, and they'll be happy with the result from any modern video camera. |
Like this...
For multi-layered editing, I transcode to Cineform Neo, which produces 120GB/hr files with virtually no loss or additionaly compression artifacts. The real question isn't editing, but what to do with the final video. It's has uses even so. You can decide after you shoot whether you want to deliver a Blu-Ray at 720/60p or 1080/60i. You can put 1080/60i on Blu-Ray and DVD, but still have nice, mice-teeth-free progressive video for online playback. |
The PS3 can playback 1080p60, but only in XviD at 19mbps with all video noise reducers off. Even the best hardware H.264 decoders only do 45fps trying to decode 60p.
I can see XviD as the only deliverable to PS3s that can still play back the 1080p60 video smoothly. All you do is mux the AC3 rendered audio in VirtualDubMod after rendering an audioless XviD AVI and you get a deliverable AVI playable on the PS3. |
Errr...Umm.....
Do you own this cam? Reason I ask, is that I would like to get some feedback/impressions of the cam's ergonomics, footage and overall usability of it. Also with Cineform Neo, does it make for a smoother editing experience with these files? |
| All times are GMT -6. The time now is 04:03 AM. |
