Scarlet Specs striaght off the Red site... Yes I got on. at DVinfo.net
Digital Video Industry News
Old November 3rd, 2011, 08:14 PM   #1
Thousands less than the canon and it really seems to blow it away.
SCARLET-X
Overview
Features
Tech Specs
Camera Views
Camera Views
SENSOR 14 MEGAPIXEL MYSTERIUM-X™
PIXEL ARRAY 5120 (h) x 2700 (v)
DYNAMIC RANGE 13.5 stops, up to 18 stops with HDRx™ 6 fps with 5K FF and HDRx On 12 fps with 4K HD and HDRx™ On
MAX IMAGE AREA 5120 (h) x 2700 (v)
LENS COVERAGE 27.7mm (h) x 14.6mm (v) = 31.4 mm (d)
LENS MOUNT Al Canon EF (PL mount optional)
MAX DEPTH OF FIELD Equivalent to S35mm (Motion) / APS-H (Still) lenses
ACQUISITION FORMATS 5K FF REDCODE RAW (Full Frame)
4K HD REDCODE RAW
3K HD REDCODE RAW
1080p REDCODE RAW
1K REDCODE RAW
PROJECT FRAME RATES 23.98, 24, 25, 29.97, 47.96, 48, 50, 59.97
MONITOR/PROGRAM OUTPUT HD-SDI and HDMI with Frame Guides and Look Around or Clean Feed 1080p 4:2:2, 720p 4:2:2 SMPTE Timecode, HANC Metadata, 24-bit 48Khz Audio
DIGITAL MEDIA REDMAG (SSD) Module : (64, 128, 256GB Media)
REDCODE™ 16-bit RAW Processing : Compression choices of 18:1 to 3:1
1-12 fps 5K FF
1-30 fps 4K HD
1-48 fps 3K HD
1-60 fps 1080p HD
1-120 fps 1K
AUDIO 2 channel, uncompressed, 24 bit, 48KHz.
Optional 4 channel, and AES / EBU digital audio.
MONITORING OPTIONS RED LCD 5" Touchscreen Display
BOMB EVF™ High Definition Viewfinder
REMOTE CONTROL REDLINK Wireless, Ethernet, RS232, GPI Trigger
WEIGHT 5lbs. Body only
CONSTRUCTION Aluminum Alloy
COLOR Battleship Gray Brain Body, Black Canon Mount and Side SSD, All DSMC Modules Black
TEMPERATURE RANGES Operating Range: 0˚C to +40˚C (32˚F to 104˚F)
Storage Range: -20˚C to +50˚C (-4˚F to 122˚F)
Jerry Porter is offline   Reply With Quote
Old November 3rd, 2011, 08:16 PM   #2
Re: Scarlet Specs striaght off the Red site... Yes I got on.
Logo-professional
Products
Store
Learn
Shot on RED
Cart 0 Items
Sign In / Register
Support & Downloads
SCARLET-X
Overview
Features
Tech Specs
Scarlet. All grown up.
With the innate ability to capture 5K REDCODE RAW stills and 4K motion, resolution sustains itself as a dominant gene in the RED family. Scarlet-X functions as a flexible device, utilizing HDRx and interchangeable lens mounts to provide you with options in a world that’s always changing. 5K burst modes snap up to 12 fps with 4K reaching up to 30 fps - helping you capture every perfect moment. All of the finest qualities of cinema and photography have now aligned, letting you take advantage of the best of both worlds with Scarlet-X.
Revolution in action.
Scarlet brings your images to life with 4K footage that will change the way you look at motion. No matter if you’re shooting a feature film or web content to go side-by-side with your stills, you will be working with crisp REDCODE RAW files that will give you ultimate freedom and control when finishing. Scarlet harnesses the power to bring life to imagery and imagery to life.
Covers. Covered.
Photography icons from Bruce Weber to Greg Williams have used RED cameras to shoot for the most influential fashion magazines in the world. Vogue, Harpers Bazaar, and W magazine have all counted on RED DMSC for covers, photo spreads and video content - getting the most out of every shoot.
Customize.
RED accessories and modules allow you to configure your camera to adapt and fit every shoot. Whether you’re gearing up for a photo shoot or are priming to film a feature, there are no limits when it comes to customizing your camera. Take advantage of modular architecture and have the perfect tool for every job.
Raw Potential.
REDCINE-X PRO software provides you with a wealth of integrated tools to import, finish, and export your images all within minutes. Offload your media using one of our REDSTATIONS and process your images with familiar grading modules and filters. Whether you’re working with a still or motion workflow, REDCINE-X PRO hosts an array of advanced features such as HDRx control and an integrated timeline to help you finish successfully. Take advantage of RAW potential with REDCINE-X PRO - available free only on RED.com.
Locations
Contact Us
RED Studios
History
Press
Gear We Use
FAQs
Sitemap
RED®, RED CAMERA®, RED EPIC®, SCARLET™, RED ONE®, REDRAY™, MYSTERIUM®, MYSTERIUM X®, R3D®, REDCODE®, REDMOTE® and all other trademarks, service marks, trade names logos, and product names of RED used on this site are trademarks or registered trademarks of Red.com, Inc. in the USA and other countries.
Copyright © 2011 Red.com, Inc. All rights reserved. Terms of Use | Privacy Policy
