Bella Catapult: captures DV or HDV video to iPod. at DVinfo.net
Digital Video Industry News
Old April 24th, 2006, 02:15 PM   #1
Now, this is interesting....
http://www.streamingmedia.com/press/view.asp?id=4598
Brian Standing is offline   Reply With Quote
Old April 24th, 2006, 02:39 PM   #2
Originally Posted by Brian Standing
At their website, they are quaoting a price for the device for under $300.00 !!! Available Fall !! Don't let the tape manufacturers get a hold of them.
Chris J. Barcellos
Old April 24th, 2006, 03:38 PM   #3
More information is avaiable at their website:
http://www.bella-usa.com/Catapult.htm
Dan Keaton
Augusta Georgia
Old April 24th, 2006, 04:30 PM   #4
This is different. I guess it records m2t to hard drive.
A great back up and cheap too. Compared to more than $1500 for firestore.
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old April 24th, 2006, 04:34 PM   #5
Assuming USB 2.0 can keep up with stream. I have had problems with some editors, using USB drives to capture to, but it also could be the editing software. This has got to be some sort of Linux OS on a chip.
Chris J. Barcellos
Old April 24th, 2006, 04:50 PM   #6
I think you're right Chris, there's some sort of firmware that helps with performance along with its ability to record frame interval recording and control from the camera.
In my current workflow I capture to a USB drive raw m2t using Connect HD and then import into Avid with no performance issues.
This is really a cool littie that I could use right now.
Can you play m2t in quicktime 7?? If so, you could do dailies on a video iPod.
Old April 24th, 2006, 04:55 PM   #7
Note to moderator. This is pretty interesting product. I wonder if it should move to the digital disk forum alomg with the firestore solutions?
Old April 24th, 2006, 06:39 PM   #8
What kind of transfer rate will an iPod take and deliver. Any idea ?
I assume you are talking about viewing dailies on a plugged in monitor. Actually haven't really looked a video iPod closely, always considered it useless for video, but can it actually output to a monitor at at least DV resolution ?
Chris J. Barcellos
Old April 24th, 2006, 06:41 PM   #9
I'm guessing Firestore might be getting nervous about this one. Seems like this is Firestore with freedom to use a drive of your choice.
Chris J. Barcellos
Old April 24th, 2006, 07:30 PM   #10
pre and post recording capabilities tells me this device has a buffer of some kind. Which leads me to believe that it would be very easy to record footage to a hard drive.
Tony Tibbetts is offline   Reply With Quote
Old April 24th, 2006, 07:41 PM   #11
I gather from the description that the Catapult simply looks at the iPod as another USB drive device. You might not even need a video iPod....
Old April 24th, 2006, 07:49 PM   #12
Yes this could affect Firestore sales except the Firestore has all of these Codecs for Avid OMF, FCP QT, Adobe Premiere AVI, DVC Pro 50 and DVC Pro HD, hence you get a lot of choices. But for HDV this is probably one of the biggest surprise today. I mean you could use a 500 Gigabyte drive and get probably 40 or More Hours of material.
Old April 24th, 2006, 09:19 PM   #13
If I can record video native to fcp, (i.e not m2t) I will definintly buy this thing the second it comes out.
Mack Fisher is offline   Reply With Quote
Old April 26th, 2006, 12:59 AM   #14
Can it get a higher data rate stream off the camera. I know that with firewire, it has a video mode that is like 40Mb/s, but I don't know if this DV mode/resolution, or another one like 640*480. But I imagine that the USB stream it gives will be the same as the Firewire gives.
Wayne.
Wayne Morellini is offline   Reply With Quote
Old May 3rd, 2006, 11:41 PM   #15
Would you need to reformat your ipod for this? This would be great, but only if I could also keep some songs on my ipod and still use it for that.
Now all we need is an ultra portable firewire mic preamp that outputs in DV codec for doing location sound with our ipod as well.
ScapeFilms.com | My Photography | IMDB Profile
Mike Tesh is offline   Reply
