DVDSP2 issues at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old September 22nd, 2004, 04:16 PM   #1
I think i posted my question in the wrong Area
Hey all folks.. man it's been a while since i last posted.. at least 2 weeks :)
well i got a fairly simple couple questions i spose.. and i've searched to no avail.. basically, whenever i do a proj in FCP and then compress it using Compressor, which exports it as a mpg2 .. which is all well and good.. i open up the proj in DVD SP 2, at which point when i'm done, i press the button 'Build/format' and DVD SP begins to encode it.. now my question is, since i bring it in as an assett that's already mpg2 encoded, is there any way i can bypass this setting as it seems that DVDSP2 is re-encoding/compressing the footage? or am i totally off base here...
2) When i do Scene selections on the dvd, when the scene ends i want it to go back to the 2nd menu or scene selection menu as it stands.. i know how to do this by adjusting the chapter markers in the main track.. however, when i DO do this and i play the film on the regular menu, for some reason at every chapter marker it goes back to the scene selection menu.. is there anyway possible i can ensure that in the scene selection part it goes back, but in the regular part footage it continues to play without being cut off?
Any help to these questions would be MUCh appreciated folks, thanks in advance! :)
2ndshooter.blogspot.com
Vishal Gurung is offline   Reply With Quote
Old November 4th, 2004, 09:13 AM   #2
1. I'm pretty sure you can't "bypass" that encoding, but you can bump up the quality in the preference settings.
2. Someone in another post suggested using the DVDSP "stories" feature for that.
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Ray Echevers is offline   Reply With Quote
Old November 5th, 2004, 12:22 PM   #3
Hey Ray, Thanks for the reply.. after much online tutorial research i believe i found the answer to my 2nd question and yeh it is under the whole 'stories' thingamabob... thanks again!
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
