Mastering Formats for different purposes - Page 2 at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old January 12th, 2005, 10:54 AM   #16
Hello Rob,
Thanks for the quick reply and the code as well.
So by inserting code, the bandwith is only "charged" one time as the video stays in residence on the viewers computer.
Is the same capability true of a Flash video, .flv format?
Regards, Al
Alan Van Vliet is offline   Reply With Quote
Old January 12th, 2005, 11:51 AM   #17
<<<-- Originally posted by Alan Van Vliet : So by inserting code, the bandwith is only "charged" one time as the video stays in residence on the viewers computer. -->>>
Exactly.
Robert M Yannetta, Loud Orange Cat Productions
http://LoudOrangeCat.com
Rob Yannetta is offline   Reply With Quote
Old January 18th, 2005, 05:38 AM   #18
RED Code Chef
That is NOT garantueed!! It is an instruction to the player, but
the cached file will be removed if you clear Internet Explorer's
cache for example. I also believe it automatically cachecs, at least
that's what it seems to do here. But there is no harm in adding
the tag and getting the maximum from the system. Just don't
count on it, money wise.
Rob Lohman, visuar@iname.com
Old January 18th, 2005, 06:26 AM   #19
Thanks Rob for your reply.
One of the "advantages" of streaming video is understand is to protect the intellectual property of the creator. By this, I "assume" that a streaming video is not cached on an individuals computer.
If this is the case, does this make any difference in bandwith usage? Or is it still the same usage for each time the video is viewed?
Regards, Al
Old January 18th, 2005, 06:32 AM   #20
RED Code Chef
Usually streaming content IS cached, so the user gets a good
experience from the whole system. However, the difference is
that the file cannot be copied (QuickTime for example locks the
file for read access) and is deleted when the player is closed.
So yes, this can wreck havoc if the player where to open the
movie again (after closing it). This should be easily to test for
yourself if you have a streaming server to test with, should be
easy to see if it is downloading again or not.
Old January 18th, 2005, 08:54 AM   #21
There's also another option for adding Quicktime to a web page to keep visitors from leeching files:
KIOSKMODE=value
KIOSKMODE is either TRUE or FALSE. By default, KIOSKMODE is FALSE. When KIOSKMODE is set to TRUE, the plug-in does not include its pop-up menu in the movie controller and does not allow drag and drop to save the movie.
For example:
<embed src="sample.mov" width="200" height="240" kioskmode="true">
Old January 18th, 2005, 09:14 AM   #22
RED Code Chef
It doesn't prevent leeching (nothing can, including streaming), but
it helps <g>
Old January 18th, 2005, 09:16 AM   #23
Quicktime Tag Attributes
For a complete list of Quicktime Tag Attributes, I have them listed here:
http://loudorangecat.com/qt_tag_attributes.txt
Unfortunately, the list was too large to print here in the boards. This list is a valuable resource for anyone needing to serve QT or MPEG4 files on their website.
Old January 18th, 2005, 09:29 AM   #24
RED Code Chef
Thanks for that Rob!
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
