Bit Rate Numbers at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old November 18th, 2009, 09:33 PM   #1
Bit Rate Numbers
This has probably been covered some ware but I can't find it. I remember reading a few years back that its best to set bit rates to a number that’s divisible by 32 (it was probably 8 or 16 in the early days). I don't know if its still applicable, but a guy in our building and I were discussing bit rates today and it came up. Is this another famous myth or is there any validity to it?
Sean Malone
Sean Malone is offline   Reply With Quote
Old November 18th, 2009, 09:44 PM   #2
Bit rates??? No. Frame sizes.. yes. But not by 32. Generally by 8 or by 4. Why on earth would bit rate need to be divisible by anything? With VBR it's essentially impossible anyway.
Old November 18th, 2009, 10:15 PM   #3
Sounds like myth. VBR is a great point. Glade I asked though, I didn't know about the "Frame Size" aspect of things.
Sean Malone
Old November 19th, 2009, 12:11 AM   #4
MPEG-1 dimensions need to be divisible by 8, but not bitrate.
Old December 11th, 2009, 09:42 PM   #5
Even if the codec doesn't require it, making frame dimensions divisible by 8 will help make encoding more efficient (even if just slightly).
Robert M Wright is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
