DVDA - Starting with a video followed by a menu at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old May 11th, 2010, 12:41 PM   #1
Hi all,
I am familiar with DVDA but I've always had to do one or the other. Meaning that I needed to create menu-based DVD's or single movie DVD's that will automatically start once inserted in a player.
Now I need to mix things up and I have no clue where to start.
Mainly what I need to do is to make the DVD start automatically, my company's short bumper will play and then the menu will appear.
How could I go about to do that?
Phil
ps, I so hope that nobody will suggest script, I am lousy at programming anything but if this is what it takes then I'll do it ;)
Phil Gosselin is offline   Reply With Quote
Old May 12th, 2010, 10:21 AM   #2
You'll find help support in DVDA under "Introduction Media". This function is also sometimes known as "First Play".
Really quite simple. In the Project Overview window (the one that shows the tree structure of the DVD, turn it on in the View menu if it isn't showing), right-click on the disk icon at the top of the tree, and pull down to "Insert Introduction Media". Done.
Preview of this is slightly tricky on DVDA (I'm on Pro 5.0a) - when you hit preview, it will bring you to the first menu. To adequately review this, you'll open Preview, hit the Stop button, then the Play button. This should replicate what happens when you first insert the finished DVD in a player.
Old May 12th, 2010, 08:31 PM   #3
Thanks Seth!
If I set the background media to a video wouldn't it do the same thing as well?
Looks like it when I preview but I didn't burn anything yet and don't to have a nasty surprise. Did you try that also? What happened then ?
Phil
Old May 13th, 2010, 10:18 AM   #4
When I've used Introductory Media the disc plays as expected - the first piece plays, then it goes to menu.
Sorry, I've not really had need for background video on a menu, though there are a few posts on same over the the vegas forum.
Seth Bloombaum is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
