how to focus while dolly-in ? - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old October 11th, 2003, 12:54 AM   #16
Introduction to Focus Pulling.
Nawaf,
As an ex-focus puller I can tell you that no matter what you try with the standard auto XL-1 or XL-1S lens, it is not going to be pretty, it cannot be calibrated to hit the same focus marks time and time again no matter what you do no matter how hard you try.
If you want to be serious about follow focus, you need to first, shelve your auto lens and pick up a manual lens. This will enable you to set actual "hard marks" that will be consistent regardless of what you do.
A First Camera Assistant or "focus puller is probably one of the most overlooked and mis-understood positions on any camera crew...except by the Camera Operator or the Director of Photography, who by the way is the one that pretty much hires the rest of the camera crew.
The focus puller, after getting his initial measurements and marks during the blocking and rehearsal of the scene, has to, on the fly, judge the distance from the camera's focal plane to the actor and "dial it in" accordingly while everything is in motion. This is generally done by eye and "feel" with no outside assistance, at least that is how I did it.
This may seem pretty straightforward but when you introduce simultaneous camera / talent movement, always at varying rates of speed, what you have is a dynamic which is different every time you roll on a scene. This is is never more evident than when pulling focus on a SteadiCam with a longer than usual lens.
I'll never forget chasing and leading Richard Dreyfuss through Hialeah racetrack while SteadiCam operator Randy Nolen kept up with Richard's frenetic pace during the scene. The only drawback was that we had a 50mm Zeiss superspeed lens mounted and we were shooting at about a T2.8! Of course, Dreyfuss's speeds and marks were always different which didn't make life any easier for the camera crew.
When I was doing it for a living, Panavision came up with a device called "PanaTape". In essence, it was a transmitter / receiver that gave you an approximete distance reading in feet and inches which you could use to adjust your focus. I found it innacurate, cumbersome and very distracting, especially when working a long lens with a small T-Stop. Too much to look at in very little time!
Focus pulling is a fine art, it has to be practiced and ultimatley done as second nature.
One very important point on following focus on a dolly shot is that you MUST have a competent dolly grip. He is the one who can make you or break you during a very slow push in with a very long lens while shooting wide open. This was especially true while on an episode of Miami Vice, we were given a shot to do that was to be the show's tag.
Fifteen feet of dolly track inside a dark Miami Beach Hotel lounge. Straight push in to the actor's eyes, full frame. The begining of the shot was a medium c/u using a 150mm Panavison Super Speed Prime, nicknamed the "crispy critter" due to its extreme shrapness and lack of compassion for focus pullers.
The length of the shot was approximately 2 minutes, using a very "creepy" dolly push as the focus continued throughout the shot until we filled the frame whith just his eyes.
I can tell you from experience that half the credit for the shot being successful belongs to my dolly grip, Jimmy Greene who expertly timed his move with my focus needs every time.
The bottom line when it comes to follow focus is that you not only need to know what you are doing but you need the proper people supporting you and, without a doubt you need to go with a manual lens in order to properly control your focus.
Keep it sharp!
RB
"The future ain't what it used to be." Yogi Berra.
www.rbravo.com
Rick Bravo is offline   Reply With Quote
Old October 11th, 2003, 01:03 AM   #17
See, and in my mind it takes a far more skilled operator to work manual focus on the auto lens! It's a weird skill foisted on us by the folks who design prosumer cameras these days...
Charles Papert
www.charlespapert.com
Old October 11th, 2003, 11:53 AM   #18
With the 16x noticable selective DOF only occurs starting at a distance between subjects of about 20 cm at closest focus (camera distance about one meter) zoomed all the way in. Of course the relative aperture becomes smaller when zooming in, increasing DOF, but zooming out even increases DOF further. Mouth & ear are just a bit too close.
Film & TV locations & production Spain
http://www.fotofilmvideo.com/
Dan Uneken is offline   Reply With Quote
Old October 11th, 2003, 04:21 PM   #19
Charles,
With all due respect I have to disagree.
Focusing on the Canon auto lens has absolutely nothing to do with skill. It is an inherent flaw of the lens design that makes it almost impossible to follow focus smoothly and consistently.
As I stated in my previous post, the lens has no calibration marks so you cannot set focus marks prior to rolling the camera. The fact that the focus ring will continue to rotate through 360 degrees is a clear indication that any focus mark made on the lens will be useless as the actual focus will never come back to your original mark.
The weakest link in the XL-1s system has to be the auto lens. We are about to acquire two more XL-1s packages bringing the total to six. ALL of the auto lenses are strictly emergency lenses in case one of the manual lenses goes down. Furthermore, I would canibalize another package's manual lens as an interim fix while the damaged lens is being repaired or replaced before resorting to using the auto.
I understand that the target users are closer to the consumer/prosumer market than the true "motion picture professional" but if your pictures are constantly out of focus you, no matter what category of filmaker you fall under, you might as well go into radio.
The manual lens makes a world of difference in the finished product when using the XL-1. It actually validates it as a production camera. The manual lens takes all of the guesswork out of focusing, allowing you to actually pull with the action. If you do go soft, then it is an issue of you either getting ahead of the action or lagging behind it.
Regards, RB.
www.rbravo.com
Old October 11th, 2003, 10:53 PM   #20
Retired DV Info Net Almunus
I could be very wrong, but I think Charles was being facetious in response to my "...professional" remark. I know he uses a 14x manual lens with his XL1.
Old October 11th, 2003, 11:24 PM   #21
I apologize if I misunderstood Charles' post, my reply was not meant to be adversarial. I take my camera work very seriously, particularly when it comes to focus, and when I cannot meet my own standards due to inadequate equipment, I guess it kind of rankles my feathers a bit.
Maybe it is just my frustration with a product that has so many positive attributes but fails in the most fundamental feature that can make or break a production.
I don't quite understand how a company, any company, not just Canon, tries to reach out to the professional filmaker but at the same time ignores the shortcomings of that same product.
I felt that it was necessary to make sure that Nawaf's question was answered in detail and to his satisfaction as focus is one of the fundamental elements of good filmaking.
Again, my apologies if I have offended anyone.
RB
www.rbravo.com
Old October 11th, 2003, 11:56 PM   #22
No Rick, on the contrary! I think everyone greatly appreciated your detailed front-line comments concerning the job of the focus puller in professional filmmaking. So many discussions here, and elsewhere, devote their energy to frame rates, depth of field and other technical issues. Precise and persistent focus throughout a motion shot is a matter generally overlooked in such discussions. But it's fundamental to a professional look, yet so deceptively difficult to accomplish on most prosumer cameras. It still baffles me how someone can pull focus often without looking through the lens in some way. But I guess it's an acquired skill that, as you say, can just become second nature with practice and knowledge of lenses.
Old October 12th, 2003, 06:12 AM   #23
Thanx everone for the replies, that was really helpfull. I never thought focus-puller's job was that tough!
I've just started getting into short-film. It's nice to know these details, so I know what to invest for the future.
Nawaf Alali is offline   Reply With Quote
Old October 12th, 2003, 11:31 AM   #24
Sorry guys, of course Ken is right and I was being facetious. It's my fault really; I find emoticons annoying and I'm not much interested in writing "hehehe" when I'm being sarcastic either, it reminds me of Beavis and Butthead or something.
I just sold my 16x IS II stock lens because I never use it. I'll bet that somewhere out there folks have spent hours using it and thus improved their skills with it, as alien as that seems to those used to rotating a barrel and landing on a mark predictably. As with Rick, the manual lens is what makes the camera functional for me.
Never been a Panatape fan either, Rick. I did a feature this summer with a Panatape fanatic AC--can't say I saw anything impressive in dailies, and I had to deal with the added gear on the Steadicam all day, every day. Annoying.
I've actually been the voice of caution for anyone considering using the Mini35 on the XL1, pointing out that a skilled focus puller is absolutely mandatory. Most users are so hungry for the shallow depth of field that they want to shoot wide open on the fastest lenses possible, without considering just how demanding that is focus-wise (and more than a few are just focusing themselves by eye--not generally successful on a 50mm or more unless you are an NFL Films cameraman!)
Charles Papert
Charles Papert is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
