Slider for under $200 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old June 8th, 2010, 08:13 PM   #1
I need a slider for a Sony A1U (light weight) for under $200
Does not have to be any larger than 2-3 ft
I do not have the time to make it myself (nor the talent).
I have an additional fluid head so it does not need o have one.
I have been looking at the indiSLIDERmini (indiSYSTEM - indiSLIDERmini) but not too sure about it.
Thoughts?
Chris Sgaraglino
The Outdoor Life Blog | Widow Creek Photography
Chris Sgaraglino is offline   Reply With Quote
Old June 27th, 2010, 09:21 PM   #2
So I got my slider for under $200 - actually just over $160, and it only took 15 minutes to put it all together.
Here is what I did...
I ordered:
1000 mm (40 in.) of 60mm wide rail WS-16-60
1 shuttle number WW-16-60-10,
Igus Rail Description: Rail: 9 mounting holes, 120 mm apart; Dim C5/C6 (first/last hole to end of rail): 20 mm; bolt size: M6
From igus, Inc. - Website, Latest News & Contact Details. Products inc. cable carriers, plain bearings, linear guides, high-flex cables for automated machinery (just call 1-800-521-2747), other lengths are available.
Cost: $158.38
From Home Depot I bought a circular level ($2.35) and a 1/4-20 x 1" bolt ($0.35)
I drilled the shuttle with a 13/64 drill bit off-set from the center, and tapped the hole with a 1/4-20 tap, and screwed in tight the 1" bolt. This bolt will hold your video head of choice.
Then bit & tap can be bought from Home Depot cheap.
I drilled my shuttle off center because I wanted room on the shuttle to mount an cold shoe bracket for lights, filters or additional sound.
I then drilled and tapped each end for 1/4-20, the same size as my tripods & monopod.
I mounted an additional head plate for my 701 (main) on one end and I can use any assortment of mounts on the other including a light stand. I can even add a couple of table top tripods for short legs.
So three holes in 15 minutes and I am ready to go.
A very thin layer of epoxy on the level and stick it right in the middle of the rail.
I'll be shooting in the Colorado mountains next week and I'll posts some clips then.
I hope this helps...
Chris Sgaraglino
Old June 28th, 2010, 12:03 AM   #3
Looks nice - appreciate the effort you made to post these pics.
A question ... when you say "Rail: 9 mounting holes, 120 mm apart; Dim C5/C6 (first/last hole to end of rail): 20 mm; bolt size: M6" ... is this just background info for us, or do these details need to be specified in the order? I didn't really understand what was being said here.
Old June 28th, 2010, 08:26 AM   #4
Graham,
Yes background information, the text "Rail: 9 mounting holes, 120 mm apart; Dim C5/C6 (first/last hole to end of rail): 20 mm; bolt size: M6" is from the Igus Website and is the description of the rail when you submit the form to get the quote. This is the most confusing part - but It shows up from their online quote system at igus - Drylin W linear slide system, look in the middle of the page and look for "Bearing Size 16 mm". That section will allow you to select your length and shuttle size.
For the 1000mm (or 40 inch) rail that is 60mm wide and the 100mm long shuttle:
When you call, all you need is 1000 mm (40 in.) of 60mm wide rail WS-16-60 and 1 shuttle number WW-16-60-10.
Chris Sgaraglino
Old August 28th, 2010, 05:10 PM   #5
Ok I went ahead and added some end caps by using nylon bolts & washers and a rubber washer from Home Depot. This keeps the carriage from sliding off the end.
Also here are some photos in use.
Chris Sgaraglino
Old August 28th, 2010, 05:12 PM   #6
A few more photos
Chris Sgaraglino
Old August 28th, 2010, 06:30 PM   #7
The first test run...
Chris Sgaraglino
Old August 29th, 2010, 05:37 PM   #8
Where did you order the track from? Is it something I can buy locally?
Evan Lloyd is offline   Reply With Quote
Old August 29th, 2010, 05:48 PM   #9
I order the rail and carriage and barings directly from Igus.com
What I ordered:
It only took a couple of days to get it, and you can tell them how long you want it to be. I selected 1,000mm or about 39 inches.
I am not aware of any local place to get it?
Chris Sgaraglino
Old August 29th, 2010, 10:26 PM   #10
I did the same thing... a very simple project and a decent result.
Chris J. Barcellos
Old September 3rd, 2010, 01:12 AM   #11
Very nice...Good work.
Now if only you could motorize the thing....
Hmmmmmmmm...
Terry Lee is offline   Reply With Quote
Old September 17th, 2010, 03:18 AM   #12
Can you say what the weight is of this system from let's say 1000 mm?
Rob deJong is offline   Reply With Quote
Old September 17th, 2010, 08:44 AM   #13
My system with the small Slik fluid head is right at 4 pounds total weight.
Chris Sgaraglino
Old September 17th, 2010, 06:50 PM   #14
Hey Chris, did you order the "camera system" that they have on Igus.com?
So the only modifications you did were just drill a hole to mount your tripod head and add some end caps and a level correct?
Old September 17th, 2010, 08:15 PM   #15
No, this is new... It looks like enough people have bought them that they packaged the parts and put them on amazon.
It looks like you'll still need to drill & tap the holes and add end caps, but all the parts are there...
Chris Sgaraglino
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
