cable support system - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old February 12th, 2006, 02:52 AM   #16
Originally Posted by Riley Harmon
O_O i want one,put a motion control head and pulley on it!!!
Working on it!!!
Bill
Cinematographers Bring Shadow To Light
Bill Hamell is offline   Reply With Quote
Old February 18th, 2006, 03:23 AM   #17
i think if you pull the lines more taught or use steel cable, it will have less tendancy to sink it or sway. try it and lemme know
Riley Harmon is offline   Reply With Quote
Old February 19th, 2006, 08:40 AM   #18
Riley,
What I did not say is this was temporary set-up.
It was done with cotton clothesline so pulling tight enough to get the slack out most likely would have resulted in breaking the line. I just wanted to get some images to post before the impending storm arrived.
The test bed will use a nylon type of line and the final product will use cable or Spectra.
Thanks for the comment. :-)
Bill
Old February 19th, 2006, 04:57 PM   #19
I was thinking...it can't be that much harder to make a rig with a seat so it can take an operator. All you need is steel cable, put one end round the tree and hook it over its self then pull the other end tight by attaching it to a 4x4 and reversing. The weight of the operator would hold it steady and a knot in the cable at the other end would stop him hitting the tree. Plus you would have more control over the shot, framming and pan/tilt etc.
Andy.
Actor: "where would that light be coming from?"
DP: "same place as the music" -Andrew Lesnie-
Andy Graham is offline   Reply With Quote
Old April 25th, 2006, 02:36 PM   #20
any update on this? hows your rig
Max Wilson is offline   Reply With Quote
Old May 20th, 2006, 07:20 AM   #21
Max,
Sorry kind of lost track (pun intended) of this thread.
No new news got on to other things, however it time with the better weather to get back to it.
I’ll post again when I do.
Bill
Old October 1st, 2007, 02:57 AM   #22
i`m very intrested to know if this came along any further. I need to make one or borrow one for filming in late october.
Cinematography Site
Nathan Quattrini is offline   Reply With Quote
Old October 2nd, 2007, 03:58 PM   #23
i made one myself last year, its pretty simple and effective
http://www.dvinfo.net/conf/showthread.php?t=76948
Old October 4th, 2007, 12:37 PM   #24
i saw that post and it looks pretty good aside some shakiness...did you ever make a tutorial?
Cinematography Site
Old October 10th, 2007, 02:07 PM   #25
Just noticed your post Nathan, yeah the shakiness was because i was on my own and i was also in the shot so i had to attach a rope and run the camera up to the start which meant getting it to stop shaking was hard, if i'm up the ladder and its an actor running i can stop the shake altogeather.
I never made a tutorial , i did use the rig recently for a promo shoot though and it worked really well.
Andy.
Old October 14th, 2007, 07:59 AM   #26
Ah. Unfortunately the shoot I was thinking to use it for is getting rushed and will likely be next week so I don`t have any time :\ Maybe next time
Cinematography Site
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
