slow crawl with a dolly - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old May 29th, 2008, 03:43 AM   #16
Hello Philip,
No problem, I can make you one. Does 21cm/second sounds good to you? Or do you want to go less speed?
What others specs do you have? Track gauge, Height of the pulley?
pricing is 900 till 1500 depending your demands and how much DIY you want to do.
Please call me: +31653201455
Best regards,
Onno
Onno Perdijk
Key Grip / Manufacturer
Netherlands
www.solidgripsystems.eu
Onno Perdijk is offline   Reply With Quote
Old January 12th, 2009, 08:34 PM   #17
Chris Li..... that was way cool..... thanks for posting that.
Old March 23rd, 2009, 06:04 AM   #18
Test number 1
YouTube - First test with DIY dolly and slow motor
test number 2
YouTube - Sunset timelapse test - with moving diy dolly
Here is a DIY slow torque motor dolly i did..
At the end of the first video you can se some stills of the motor i used.
Its a regular 230v mirrorball motor. it moves at about 12cm pr min.
to slow it down to 6cm pr minute i did a pulley system with two strings.
Vegard Paulsen is offline   Reply With Quote
Old March 23rd, 2009, 06:37 AM   #19
You might try here for motor ideas.
https://bmumford.securewebsites.com/...ary/index.html
Rotary Table Controller
Good Luck with your project!
David W. Jones is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
