mini dv to dvd, how to get highest quality?
I'm an audio guy, but my son and I have a video production business together. We have a little over one minute video we shot which will be shown on a 17 inch tv/dvd combo player at a trade show. The piece will loop the video throughout the day at the show. Its a cheap player ($279) and we're not really too happy with how some of the footage looks after authoring to DVD. We checked the disc on one of the displays that will be used and the display is part of the problem, but we're still thinking the video should look better than it does. This is after trying many different settings etc.
The original footage is mini dv, shot on a Canon GL2. The lighting is good and the subject matter is two people standing and talking to camera. No moves just a fairly wide shot. We're editing on Final Cut Studio and going to DVD studio via Compressor. The people are wearing red tops and we color corrected to help the issues that causes, but I would describe the quality as looking like a vhs copy. Any suggestions? Is it possible to do any better? Would burning at a slower speed help? We have a bunch of versions to make and need to get this figured out today. All help would be appreciated! Regards, Bernie |
First thing to ask Bernie is when played side by side, is the DVD a lot worse than the original Mini DV edit master tape? It shouldn't be - DVDs are mightily compressed, but the colours and sharpness hold up well - it's the graininess that increases if you have rapid picture changes (fades, dissolves etc) and have used a low bit rate.
So if the DVD does look worse that the tape then I suggest that it may be the MPEG compressor or the bit rate. Use a CBR of 7 or 8 mbps and it should be indistinguishable from the original for all intents and purposes. Speed of burning won't help you at all, and neither will changing blank media. How does this set-up look playing a Hollywood DVD? Maybe there's a fault in the wiring? Or in the TV set-up? tom. |
Personally, given the display that you will use (a cheap 17" TV/DVD combo), you might as well just use a cheap standalone DVD recorder and hook it up to the camcorder's analog outputs or, if you have a recorder with FireWire input, use the direct FireWire connection.
When I have compared DV transfered to DVD the above ways to using a PC to author the DVD etc, it isn't possible to tell the difference on a conventional, small TV. Indeed, I was hard pushed to see any difference on a proper video monitor. |
I'd second John's comment - I frequently use a standalone cheap DVD recorder wired through firewire, and the results often look so close to the original that it's difficult to tell which one is which - and it's much quicker, of course.
#5 |
I appreciate your input. I am aware that we might get better quality by going to a recorder, but we have 38 different versions to do and they all need to loop automatically on these displays. Yes, there are 38 displays, and 38 different versions. So is your suggestion to go from Final Cut, back to tape, and then record the versions one by one onto the separate DVDs? How would we get the looping then? We've had input about this quality issue from some other knowledgeable people here at home and they're saying we can't expect it to look that good because of our original source material, mini dv, is compressed too and that's where the quality is going down. I'm glad you've had good results but we can hardly say the DVD is close to the same looking as the output of our edit.
Thanks, Bernie |
#6 | |
Thanks, Bernie |
#7 | |
Thanks, Bernie |
#8 |
If the results are that poor then something is wrong in the workflow.
For testing purposes, render FCP's timeline to DV and send it to the camcorder via FireWire. Compare it to the original and DVD versions. Make sure you are viewing all of them on the same video monitor/TV (i.e., not the computer). What does the DVD version look like on the Mac? Can you post example frames from the original and DVD version so we can have a look? |
#9 | |
So, lets see if we can narrow down potential fault points in the workflow. What is your method of capture of the GL2 content into Final Cut? Are you certain that you are editing with properly calibrated monitors? What settings are you using for capture and your timeline? Instead of burning the DVD from DVD Studio Pro, trying building a disc image (.img) first, and then mount the image on the Mac and open the file using the Mac's DVD player. I'd be interested to find out how the DVD disc image looks in comparison to the discs you have burned so far. -Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?" - Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974 |
#10 |
Thanks all for your help!
My son did come up with a better work flow that has really helped. It turned out to be a work flow issue. Before, he was doing a standard dv capture, then outputting to compressor to convert to MPEG2 and then burning the DVD. Instead he captured using ProRes 422HQ and then let DVD Studio handle the MPEG2 compression. The finished discs look a lot closer to the original footage. As I write this he is burning and checking the 39 discs that will be delivered tomorrow. I had a feeling there was a way to make this work better and I'm proud of him for figuring it out. All of your points were valid and good ideas and we appreciate your input! We've both learned a great deal about DVD authoring since starting and trying to complete this project. If you ever need audio advice I'm your guy. Been doing it for 30 years. All the best! Bernie PS We still have the crappy displays to contend with but at least it looks better on a good monitor. That tells us we got all we could out of the video source. |
| Thread Tools | Search this Thread |
