NTSC DVD playing back in PAL Asia at DVinfo.net
Old January 2nd, 2004, 07:28 AM   #1
I'm creating a DVD title for a client that might possibly take it to China to display there. Now i know that DVD titles sold in China can playback here fine, but since China uses the PAL standard, that just complicates things. Also it is known that a lot of TVs in China supports both standard. But what requirements are needed on the DVD player side? It needs to be region free obviously(But can't I author without a region put in?) Does the player need to be a PAL player that supports NTSC(Or do all DVD Players supports both format?) What can I do while authoring to ensure that my NTSC DVD title will playback in China? Thanks
Old January 2nd, 2004, 08:07 AM   #2
Outer Circle
You will need a multi-system DVD player, these are also region free.
Old January 2nd, 2004, 08:16 AM   #3
RED Code Chef
Are you sure on that frank? To the best of my knowledge all
DVD players will be able to play all formats. Usually the TV
(or whatever you are using to display the DVD) is the problem
(it gets the NTSC or PAL signal). There are multistandard DVD
players that can CONVERT the signal on the fly. Then it can
convert an NTSC DVD to PAL while it is playing.
You cannot do region coding (or encryption for that matter)
as a consumer. Only professionally authored DVD's can do that.
So no worries on regions etc. The only "issue" is the NTSC / PAL
one.
Rob Lohman, visuar@iname.com
Old January 2nd, 2004, 08:23 AM   #4
Outer Circle
To the best of my knowledge all DVD players will be able to play all formats
Not here in North America; and for a DVD player to play all formats and convert the signal, it would have to be a multi-system / region free unit. Perhaps in China, most DVD players are multi-system.
Old January 2nd, 2004, 08:54 AM   #5
RED Code Chef
Yes, for it to convert it must be a multistandard capable player.
We agree on that. I just thought all player could HANDLE all
discs. Well, all european (whether or not they can CONVERT the
sgnal) do anyway.
Old January 14th, 2004, 11:23 AM   #6
Yep if you make the disc Region ALL, Regions 1-8 are flagged, then it'll play on all players pretty much. Even if the player is Region 2 only it will play as Region 2 is flagged on the disc. Some Region 1 players are suppose to be about in the US that don't like Region All disc but they are few and far between at the moment.
As mentioned it's the tv standard that play's a big role and sending a NTSC region ALL disc to PALland has a far greater chance of playing than the other way around.
On the topic of Regions, I'm testing TFDVDEdit 2 at the moment and this topic came up while I've been playing. It's been pretty much said that for region codeing to work reliably you need to enable copy protection(CSS) and write to DLT. I have a dvd-r written which we're testing and it's 'Region Mask code' is set to '0' and working perfectly so far. All non-modified players would not play the disc and put up it's Region warning. So it's got some heads scratching on the tfdvdedit board.
Jake
Jake Russell is offline   Reply With Quote
Old February 4th, 2004, 11:28 PM   #7
Yang,
I have tried played a PAL DVD with a normal DVD player in Canada. It played... however the TV was not multisystem so only saw distorted pictures and noise.
Shouldn't need to worry about DVD players sold in Asia. Almost all DVD sold in this region is in fact NTSC! Surprising but this is the fact. This reason is that imported DVDs (LD in the past) from US and Japan are very popular. All you need to worry about is the TV.... many TV sold in China are multisystem... however, not all.
If your client is in HK. You need not worry at all. 99.999% DVD players and TV sold after the 80's in HK are multisystem.
PS. DVD players sold in HK don't have regional code restriction at all!
Paul Leung is offline   Reply
