Adobe Encore DVD audio at DVinfo.net
Old January 28th, 2004, 08:53 PM   #1
I just my mini movie on DVD using encore, and the bass seems to be very high. I can hear like crackling sounds and it's bad. How would i fix this problem???
Mike Zorger is offline   Reply With Quote
Old January 29th, 2004, 09:14 AM   #2
would i have to lower the bass in premier or something??
Old January 30th, 2004, 06:58 AM   #3
So no one uses Encore??????
Old January 30th, 2004, 07:46 AM   #4
Mike, I don't use Encore, but I was wondering this: have you tried the DVD on a number of DVD players, just to see if it might be how it plays on one DVD player and not another? I know I've had this happen, where the sound is quite different, depending on the player...
Just a thought.
Chris Long is offline   Reply With Quote
Old January 30th, 2004, 07:52 AM   #5
no it starts after I export it as mpeg2 from premier pro, and if i watch my video in encore before i burn it, it also has the high bass crackling sound.
Old January 30th, 2004, 04:21 PM   #6
I use Encore and I don't know how it would change the audio like that.
Bryan McCullough is offline   Reply With Quote
Old January 30th, 2004, 04:45 PM   #7
Sounds like it's the mpeg encoding that is distorting your bass response. Make sure the MPEG settings are correct prior to encoding and try re-encoding.
I have questions for a person like yourself who has used encore. Can you really make anything a DVD button on the screens rather than the big square button limitations of most DVD authoring softwares?
Alex Dunn is offline   Reply With Quote
Old January 31st, 2004, 11:19 AM   #8
With Encore, yes. Anything you can create in Photoshop you can have be a button.
Any DVD authoring program that works with Photoshop files should also do this, but Encore and Photoshop are incredibily integrated.
Before Encore I used DVDit and made buttons with Photoshop.
Old February 1st, 2004, 10:18 AM   #9
ok i'll check my setting for exporting the mpeg2. Do you konw the setting i should be using??
Old February 2nd, 2004, 08:27 AM   #10
Mike, I'm a relative audio novice too, but I think for NTSC DVD it has to be either 48K or 44Khz. I'm not in my office, can anyone else run down the required properties?
