HELP with dvd burning at DVinfo.net
Old February 15th, 2004, 10:56 AM   #1
OK here we go again. I have in stalled a belkin 3 port pci card into my computer. With a 4 pin to 6 pin firewire belkin dv cable. Now i get a message that "no valid video capture device is detected. So now what settings do i need from my GL2 if any?
Steve Olds is offline   Reply With Quote
Old February 15th, 2004, 11:27 AM   #2
Warden
What software are you using for video capture?
Jeff Donald
Carpe Diem
Old February 15th, 2004, 01:45 PM   #3
Sonic My DVD that came with my sony dru510a. I'am not sure that the driver downloaded for the Belkin pci card that I installed. The pci card came with out a cd to load a driver. I use windows xp home and it should have found a driver for it. Sent an email to belkin with out a reply yet. Thanks
Old February 15th, 2004, 03:01 PM   #4
Warden
Are you trying to transfer DV directly to your DVD burner?
Jeff Donald
Carpe Diem
Old February 15th, 2004, 04:35 PM   #5
Yes I can or atleast the program will let you burn direct from camera to dvd. So I can go from the dv in/out on camera to the firewire port on the pci card I just installed. New dv cable and new firewire pci card.
Old February 15th, 2004, 04:56 PM   #6
Warden
The Sony dru510a is not on Sonic's approved hardware list. It's always possible that the list is not up to date. What OS are you using?
Jeff Donald
Carpe Diem
Old February 15th, 2004, 08:27 PM   #7
Using xp home. Sonic mydvd came with the Sony dvd burner on a disc. I also tried a new dv cable so I do not think I would have 2 bad ones in a row. I also reinstalled the sonic program.
Old February 15th, 2004, 08:32 PM   #8
Warden
Just because it came with the DVD burner, doesn't mean it supports all the functions. If you go to Sonic's site, you'll see that your burner is not listed in the supported hardware. It's possible that the list has not been updated, it's possible that your drive is not supported. I would contact Sonic for assistance also.
Jeff Donald
Carpe Diem
Old February 16th, 2004, 12:46 AM   #9
I have a belkin card and it was a bit funky at the begnning .....
i remember i ended up deleting / reinstalling the ethernett driver / generic host controller drivers that came with my pc, right from the pc recovery disk, and that solved whatever was going on.
however, i am testing out a quickstream drive and it does not recharge though the belkin 6 pin. does anyone know if the belkin 6 pin on the pcmia laptop card is powered / hot?
Emmet Lucey is offline   Reply With Quote
Old February 16th, 2004, 10:41 AM   #10
Warden
I don't believe laptop cards can supply voltage for charging etc. I know they won't power hard drives. I don’t believe it part of the PCMCIA specifications.
Jeff Donald
Carpe Diem
Old February 16th, 2004, 10:54 AM   #11
Ok, thanks 4 the info jeff.
Old February 16th, 2004, 12:44 PM   #12
Jeff and Emmet,
Since this being a holiday here Monday I can not get an answer from anyone at Belkin or Sonic so..... I removed the pci firewire card from the slot I installed it in. As Windows did no detect it when I restarted my system after I installed the frist time. Start and restart untill blue in the face.
Now that I moved the pci card to another slot and restarted my system back up, now windows finds the new hardware! I guess maybe there is something wrong with the card slot or something I don't know????
So after all this I can now burn a dvd direct from my Canon GL2 to the dvd. So thank you for all the help over the last day or so.
Steve
Old February 16th, 2004, 03:29 PM   #13
good!
basic law of pc aggrevation - that which does not kill you makes you stronger! :-)
Old February 17th, 2004, 08:02 AM   #14
So now that I have fixed this problem does that make me a computer GEEK or just lucky? Or do I have to face more Woes in DV land?
Old February 17th, 2004, 11:51 AM   #15
"Or?" Steve, what makes you think it isn't all of the above? ;-)
Marcia Janine Galles is offline   Reply
