More than 120 min DVD burning at DVinfo.net
Old February 18th, 2004, 03:16 AM   #1
Hello...
I am working in Nero Vision Express and I want to make a DVD which will be more than 120 min long. Inside Nero there is a QUALITY SETTING where you can set STANDARD PLAY (120 min) and also LONG PLAY (180 min) and EXTENDED PLAY (240 min).
When I burn more that 120 min on a disc (EXTENDED PLAY for example), the disc will not play on my DVD player.
Maybe I am recording on wrong media? Disc is 4,7 GB and 120 min. Maybe there is a mistake?
Thank you...
Marko
Marko Zorec is offline   Reply With Quote
Old February 18th, 2004, 06:41 PM   #2
RED Code Chef
This basically should work since it is just reducing the bitrate at
with the MPEG2 is being encoded. Can you please describe your
complete workflow (do you use any other applications for mpeg2
encoding, authoring etc.?) and what profile you are using in Nero?
More then 2 hours (120 minutes) of video will probably not look
to good on a 4.5 GB DVD-R disc, though.
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
