DVD album recommendation at DVinfo.net
Old June 29th, 2005, 11:25 AM   #1
Can anyone recommend an album to store home made DVDs?
I searched a bit and there are mixed reviews of the Xtreme CD/DVD Case, and the cdProjects DVD Portfolio for instance.
The Case Logic DVD Wallet does not seem to be very well liked.
Any other optins to consider that have worked for you?
thank you
Maximo
Maximo Salaberry is offline   Reply With Quote
Old July 3rd, 2005, 05:23 AM   #2
RED Code Chef
I'm not 100% sure on what you mean exactly, but I put my burned DVD's
either in regular CD cases or the "normal" DVD ones (that the movies come
in as well), depending on the type of project and whether I've designed a
cover or not.
Rob Lohman, visuar@iname.com
Old July 5th, 2005, 11:20 AM   #3
This is the type of album I'm thinking about:
http://www.amazon.com/exec/obidos/tg...=UTF8&v=glance
I'm looking for the most minimalist way to archive DVD and also sth that would let me see right away which DVD am looking for (i.e., clear sleeves).
I'll try this one and will let you know how it works.
There;s a more pricey one that i'm not sure is needed but may be higher quality indeed:
http://www.amazon.com/exec/obidos/tg...X0DER&v=glance
Old July 7th, 2005, 04:13 AM   #4
RED Code Chef
I have a lot of such caselogic cases in use here, but mostly for CD(-R)'s and
not DVD's. However, they have worked very well for me in that regard.
I make sure the material inside is soft so it should not scratch the disks.
However it will be more easily to scratch then in a case, that's just the
nature of the beast I'd say.
