Encore 'Play All' and chapters at DVinfo.net
Old January 29th, 2013, 07:38 AM   #1
Hi all - I normally send my Premiere project with chapter marks directly to Encore using dynamic link and create chapter playlists for each chapter.
I want to start exporting each chapter individually from Premiere and then bring them into Encore as individual assets.
How can I have an option to play all (so each asset end action would be to play the next) OR have them play individually ( so that the asset end action would go back to the menu)
Thanks in advance
Pete
Old June 13th, 2013, 07:49 AM   #2
Re: Encore 'Play All' and chapters
While this is old still figured an answer should be here.
You can make a bunch of time lines. Then select the first time line and set the end action to play chapter 2, and then chapter 2 has an end action for chapter 3. etc etc.
On the menu system however you point to the chapter you want but then set the override to come back to the menu. This will cause the selected option to play but then override the end action and return to the menu. I havent done this setup in ages but pretty sure it still works the same on the newer versions of Encore.
-Josh C.
Simple Thought Productions - Life @ 30,000 Words per second
Josh Chesarek is offline   Reply
