Help making DVD from FCP!? at DVinfo.net
Old July 12th, 2006, 01:15 PM   #1
Hey guys, i just finished a DV project that is a few minutes over an hour in length. Anyways i try exporting this as a self-contained quicktime over to iDVD and it will not accept it because it says the file is too large (4.5gb) and a dvd only holds 4gb. I need some advice/tips on the best way to go about getting this onto a DVD without losing quality etc. Thanks
Shane Miesse is offline   Reply With Quote
Old July 12th, 2006, 01:16 PM   #2
oh, also, i would like to make some basic menus and use a picture as the main background of the menu in the DVD, i also tried using toast 7, BUT after i burnt the DVD there was no video!
Old July 14th, 2006, 12:00 PM   #3
Somewhere in the preferences of iDVD you should be able to change the encoding settings to try to fit more content of the disc. For the menu just choose a very simple theme and from the finder you should be able to drop a photo in as the background for your menu.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply
