Image sequence Motion 5 help. at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old February 10th, 2012, 07:30 AM   #1
hello.
just added Motion 5 to my set up..need it image sequence..QT 10 is a no..so I heard Motion 5 was good for this job (and others).
BUT.
click import
select first thru last image
check image sequence
ok
Program hangs..wheel goes and goes.
my image sequence is from Canon T21..files names are IMG_2645.JPG and on..for exemple.
why..why..why why?
any ideas.
FCPS2, G5 Dual core 2.0 GHz, 2.5 Ram, Dell 2408, M-audio DX4, DVX 100A, Sachtler DV6, Manfrotto 561B, Zoom H-4, RE-50, AT890 shotgun, steadicam Merlin,
Osmany Tellez is offline   Reply With Quote
Old March 19th, 2012, 02:16 PM   #2
Re: Image sequence Motion 5 help.
I don't know if this will help you or not. But I can't seem to find a "share" button or "export to" button to send things into Motion from FCPX.
So what I have to do to work on anything in Motion, including .jpg is put it on a storyline in FCPX and export to ProRes then import to Motion.
That should work for you. But I think its very dumb to have to do it this way. Not to mention there will degradation in footage or stills when doing this (from what I've read online).
Anyone else know a better way or are we missing something?
Caleb Reynolds is offline   Reply With Quote
Old March 25th, 2012, 09:09 AM   #3
I also just added Motion 5 to my workflow, after having been in FCPX since it came out. I haven't really done anything yet, but like the abot person, I'm very surprised to fine that there is no rountripping or easy workflow between FCPX and M5. What's up with that? Anyone know if it will be addressed in an update? Is there a good/better workflow between the two, and it's just different than the previous "send to Motion" roundtrip thing?
Fullerton Images - Vimeo - FaceBook
Ben Fullerton is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
