best tool for this audio noise? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old June 7th, 2012, 09:44 AM   #1
I have about a half hour of footage in which there's a sound that's almost like fingers snapping. It's louder than the guy I was interviewing, and happens on top of the dialog. I don't think it's a chronic problem, because I have many hours of footage without it.
I've looked through the FCP X Logic Effects manual, and I don't' see anything obvious to fix this. Would welcome suggestions.
Philip Fass is offline   Reply With Quote
Old June 7th, 2012, 05:02 PM   #2
Re: best tool for this audio noise?
FCPX X will let you use any 64 bit AU plug in.... I recentlyly used ones from iZotope to declick a load of wireless mike splats.
They have a package of repair tools... But note that the Spectral Analyser won't work in FCPX X . The de clicker, declipper and noise removal tools all work great. The de cipper turned out best for my case, yuots might be different. There,s a demo too.
Waves also have some tools ... 64 bit , but I have't tried them.
lee
Lee Faulkner is offline   Reply With Quote
Old June 8th, 2012, 12:57 AM   #3
Was the noise made by a cellular device close to the cables? Even if phones are set to silent you will still hear that weird electronic interference (usually a series of clicks and a buzz) just before the call is received.
Its happened to me on one occasion, so now phones are set to off (not to silent).
Simon Wood is offline   Reply With Quote
Old June 8th, 2012, 05:45 AM   #4
Lee, I think I'll try the demo. Thanks.
Simon, I guess it's possible. I did have my iPhone in my shirt pocket, set to silent. It was probably a couple of feet from the mic cable.
Old June 11th, 2012, 06:06 PM   #5
I can confirm that the Waves W43 Noise reduction plugin works in FCPX. It's only $65 and provides a gentle broadband noise reduction . No noise print sampling ... the iZotope one does that.
Best
Lee
Old June 12th, 2012, 05:50 AM   #6
It wasn't your phone. The interviewee could have had a pacemaker.
Were you using a clip-on mike? I have a lot of problems with mens cell phones in shirt pockets or jacket vest pockets and clip-on mikes. Women usually have their phones in bags or side waist pockets and these are far enough away to not be a problem.
Old June 12th, 2012, 08:51 AM   #7
It was a clip-on, wired lag, but he didn't have anything in his shirt pocket.
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
