(FCE) Trouble Exporting 16x9 at DVinfo.net
Final Cut Suite
Old August 11th, 2007, 01:50 PM   #1
I have been trying every way I can think of to export a quicktime format file of a project shot in 16x9 on an XL2, but I always get thin black bars at the top and bottom of the frame and the image still has a bit of squeeze to it.
I'm choosing "Export" then "Using Quicktime Conversion" and then under the size setting checking the box that says "Preserve Aspect Ratio" and picking "Letterbox" from the drop down menu. If I don't check that box and pick letterbox, I just get a 4x3 image with anamorphic distortion.
Any ideas?
Kevin
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply With Quote
Old August 12th, 2007, 08:58 PM   #2
Don't export using QuickTime Conversion. Simply export as a QuickTime Movie. Your aspect ratios will be maintained, and you will get the best quality export possible. To save disc space, export as a referenced movie. Only use self-contained if you plan to sent the exported movie file to another computer.
Waldemar
Waldemar Winkler is offline   Reply With Quote
Old August 12th, 2007, 11:57 PM   #3
I've only been able to get this to work correctly in Compressor:
In version 2: Use the Letterbox filter in the filters you can apply to a Compressor preset. Choose the 16x9 option, and it will correctly inset a anamorphic source timeline into your compressed file.
In version 3: Use the Geometry tab, use "Output Image Inset" pulldown at the bottom of the inspector. There is a preset choice for 16x9 as well.
My Work: nateweaver.net
Old August 13th, 2007, 10:59 AM   #4
what's wrong with 4:3 distortion? Can't you just hit apple J in quicktime and check clean or production?
Aric Mannion is offline   Reply With Quote
Old August 13th, 2007, 01:57 PM   #5
He wants a 16x9 source letterboxed in a 4x3 export. It has to be rendered that way, it's not a checkbox option in playback.
Old August 14th, 2007, 07:51 AM   #6
As others have suggested, exporting a "Quicktime Movie" will give you a file that has the same settings as your timeline. However, if you want to use "Quicktime Conversion" the easiest way I've found is to put in a "Custom Size" (i.e. 1024 x 576). Don't worry about the "Preserve Aspect Ratio" settings.
Or, if you don't want to export again, just edit the settings of your existing Quicktime movie so that it displays as widescreen (i.e. 1024 x 576 as opposed to an anamorphic image that hasn't been stretched out yet). In Quicktime go "Window > Show Movie Properties". Click the "Video Track" tab, then the "Visual Settings" tab. Deselect the "Preserve Aspect Ratio" check box. Enter a 16:9 value (i.e. 1024 x 576). Make sure "High Quality" is checked while you're there. And that's it... It should work now...
Chris Hocking is offline   Reply With Quote
Old August 17th, 2007, 04:12 PM   #7
If it's rude to start a thread and then not jump back into the conversation for a while, I apologize.
I should've been more specific when I asked the original question. I was trying to export for You Tube. That's why I was using "Quicktime Conversion." I was wanting to get a 16x9-not-letterboxed version of my short posted. After looking around You Tube, I see that just about everybody does it as letterboxed. I'll just have to settle for that until You Tube changes things around.
Thanks for the tip on Apple-J and then changing the settings. That looks like it will solve another problem for me.
Thanks for the help guys...
www.grvideo.net
Old August 17th, 2007, 05:42 PM   #8
I think YouTube automatically recognizes 16x9 and adds its own letterbox when it encodes to flash. It's a no brainer. Just upload in 16x9.
Tim Dashwood
Old August 17th, 2007, 07:24 PM   #9
The YouTube player is always 4:3. You cannot change the YouTube player to display a true 16:9 image. As Tim suggested, if you upload a true 16:9 movie, YouTube's compressor will automatically letterbox the video. This may change when they move away from Flash and stick with H.236.
