FCP 6 crashing on Export
I'm trying to export a 39 min documentary (hdv 24p) to an uncompressed .mov.
FCP keeps crashing on me about 28min into the export or less. Advice is greatly needed. Thanks in advance. |
are you exporting via compressor or what are your settings. I have been having an issue when compressing through compressor it locks up/ crashes. Look into the the batch monitor in compressor in there you will see a little button with an i click on it also you may see it say error this is what has been happening to me, once you click on the i then go to the log and scroll to the bottom. Let me guess it says it can not find file FCP ####### #### #### then a bunch of numbers. This refers to a temp file that is created when you hit export using compressor in FCP you will see this number pop up when you click on using compressor in/ above the Browser window in FCP it will pop up as a tab next to the effects tab. Let me know if I am on the right path here. And I will continue and you need to call apple and let them know what is going on I have been working with them on this issue. But still no answer
Brandon |
| All times are GMT -6. The time now is 12:27 AM. |
